Cobra CB Trouble
Discussion in 'CB Radio Forum' started by rookie89, Nov 12, 2008.
  1. rookie89
    rookie89 Bobtail Member
    Hi everyone
    This is a first time posting here for me, but ive been readying alot of the threads on here since I was attending driving school. Anyway i am going across Canada at the end of the month to go drive a water truck in alberta and I decided I should wire a cb up for myself for the long drive.
    I bought an older cobra off my friend who used to drive a truck and I bought a magnet mount antenna from walmart. In his classified add the model of the radio is a cobra sound tracker 29 ltd. st.
    Before I went to pick it up I did some prewiring so that all I had to do was plug it in so I could make sure it worked before I payed for it. He said the SWF was really high on channel 1 (the trucker channel) around here so I guess what im trying to ask is how do I adjust this radio for maximum performance. I know nothing about cbs so If someone could make some sense of all the abreviations on the buttoms that would be great.
    Thanks
  3. BOOTYMONSTER
    BOOTYMONSTER Light Load Member
    99
    64
    Oct 3, 2008
    RICHMOND VA.
    first you need to get a swr meter . dont trust the one built into any radio . you will need a 3 foot coax jumper for the swr meter . im going to give you two links to go look at . one will tell you how to use the swr meter and the other will tell you how to use the meter to tune the antenna to a acceptable swr .
    http://www.youtube.com/watch?v=jRWKZskxcs0
    as far as adjusting the radio i guess you mean tune it up . id suggest getting a good tech to do an alignment and tune up on it . dont just go to anybody , ask around for whos good locally or you could send it to one of the few good tech available online .
    also be sure to double check your coax and its connectors to be sure theyre in good condition .
    by the way......... welcome to the forum rookie89
  4. rookie89
    Thats the most helpful things i think i ever found on youtube. Im going to town to pickup a meter from radio shack and a cobra magnet mount antenna. They just came onsale for the same price as the one I bought at walmart yesterday.
