Code 559 ISX15 2350
Discussion in 'Trucks [ Eighteen Wheelers ]' started by skman, Jan 21, 2024.
  1. skman
    skman Medium Load Member
    313
    133
    Aug 26, 2013
    Saskatchewan
    I'm getting an intermittent 559 even at bobtail when I'm running it hard.
    Fault Code: 559
    PID: P157
    SPN: 157
    FMI: 18
    LAMP: Yellow
    SRT:
    Injector Metering Rail 1 Pressure - Data Valid but Below Normal Operational
    Range - Moderately Severe Level. The ECM has detected that fuel pressure is
    lower than commanded pressure.
    It'll run good for a few miles with boost hitting 33psi...then it'll flash a check engine for a few seconds and go away. As soon as it does that, I'll lose torque and my boost will only get to about 22psi.
    When we check it in Insite...this code is present but INACTIVE. But the de-rate doesn't clear when the code goes inactive?
    We've changed filters, tested injectors, changed relief valve and fuel actuator. Also, swapped fuel pressure sensor.
    Had a decent amount of bigger air bubbles (under throttle) when checking with clear hose so we bypassed the F/W separator and bubbles stopped.
    Took it for a another drive and same thing.
    Engine was rebuilt about a month ago and high pressure pump head was rebuilt at the same time.
    We've checked all we can think of so we're going to pull the pump head and take a look at that again.
    Any other ideas that I should check?
    Edit: Also, does anyone know what the maximum commanded pressure should normally be at full throttle/full boost?
  3. AModelCat
    164,210
    What did they do to test the injectors?
  4. skman
    313
    133
    Aug 26, 2013
    Saskatchewan
    They did leak down and some other test (can't remember).
    They're new injectors that were put in at rebuild but one did fail so we replaced it and then it tested good in shop.
    But on the test drive we still got the quick 559 code and de-rate.
  5. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
  6. skman
    313
    133
    Aug 26, 2013
    Saskatchewan
    gokiddogo Thanks this.
  7. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    I don't see any low pressure fuel system testing being done. I would start there. Inlet restriction, low side fuel pressure too.
    skman and AModelCat Thank this.
  8. pushbroom
    pushbroom Road Train Member
    1,788
    7,393
    Sep 1, 2012
    Assuming the fuel return checks are being done properly and all under spec, when you pull the pump head push the plungers into the pump head and make sure they bounce back out. If they just shove in and stay in the pump head check valves have failed.
    I have had aftermarket injectors only fail the return test when they are hot but not cold.
    Whats your measurements on the fuel return tests. Anything close to failing?
    High Stepper, gokiddogo and AModelCat Thank this.
  9. skman
    313
    133
    Aug 26, 2013
    Saskatchewan
    I'm not sure...I wasn't there for the testing. We're going to test those plungers tomorrow and if they're good...I'll probably end up taking to Kenworth this week to do more accurate testing
    It would be there already but weather has been nasty here for a week or so and the dealership is 150 miles away.
  10. skman
    313
    133
    Aug 26, 2013
    Saskatchewan
    Took pump head off and had a broken washer. Ordered the parts and hopefully have it back together tomorrow morning....and working
  11. Atl ahiska
    Atl ahiska Bobtail Member
    4
    Hey there, having same issue. You said the washer was broken, is it the washer under the plunger? I unscrewed the plungers and both of them have cracked washers. Is that what you talking about? Did you get them replaced and issue fixed? Please lmk
