Columbia can't keep a charge
Discussion in 'Freightliner Forum' started by D&Ptrucking, Dec 13, 2014.
  1. D&Ptrucking
    D&Ptrucking Bobtail Member
    10
    Oct 26, 2014
    newer batteries - We have 3 05 Columbias. Drive 10 hours, 12 hours later the battery is dead. Sending 12 volts according to the dashboard. Thats not giving us and sounds when key is turned. If we charge off another truck, it will shoot up to 14.1 volts and the engine will turn over. Any idea why we can't start up after 12 hours? Thanks
  3. Skate-Board
    Skate-Board Road Train Member
    3,801
    3,996
    Aug 9, 2014
    Merrimack, NH
  4. Starboyjim
    Starboyjim Road Train Member
    2,039
    1,425
    Dec 10, 2011
    Weed, CA
    My '08 Columbia charges 14.0-14.1 all the time. I agree that your alternator isn't putting out enough voltage. They don't cost much and they're easy to r&r. One question, OP. Are your batteries all the same? Same age? Size? I was having some issues with holding charge, some other nagging things I don't recall, anyway I bought 4 new 950 cold crank amp batteries from Fleet Pride ($274!) cleaned everything up, and all the electric problems went bye bye. Charge rate was the same with or without the battery replacement, though, so I guess my alternator was doing it's job for me and it was battery problems. Truck came with 3 different age batteries, 2 different types, all 1,000cca. I really like what happened when I got the 4 new ones installed. My $.02. Good luck, I hope it works out easy for you D&P. (and affordable!) J
  5. baseballcoach
    baseballcoach Light Load Member
    105
    72
    Mar 23, 2011
    Illinois
    Not that common but could be a bad cell in one of the bats, if one cell is bad it drains the others when trucks off. U can test a cell but darn if i know how.
    traderpats Thanks this.
  6. Skate-Board
    3,801
    3,996
    Aug 9, 2014
    Merrimack, NH
    Logic will tell you the alternator is bad. 12 volts on the dash and 14.1 when hooked to another truck.
  7. cabwrecker
    cabwrecker The clutch wrecker
    1,626
    1,425
    Mar 23, 2012
    Voltage regulators gone.
  8. windsmith
    windsmith Road Train Member
    7,296
    6,032
    Sep 2, 2011
    NEPA
    Had a similar problem with a 98 Pete that I drove. Corroded battery cables. 12 Volts is low, however - so have the alternator tested, and check all the connections between the alternator and the batteries for corrosion.
  9. Skate-Board
    3,801
    3,996
    Aug 9, 2014
    Merrimack, NH
    Part of the alternator
  10. spyder7723
    spyder7723 Road Train Member
    15,471
    25,078
    Mar 31, 2013
    sarasota, fl
    It amazes me how many people buy trucks without having a clue about what makes an engine run, or even howBatteries work. You don't have to be a certified mechanic but a truck owner needs to have the know how for this basic stuff. A little bit of effort educating yourself will pay off in tens of thousands of dollars saved.. For example, a thirty dollar tool will check every battery, alternator, and starter you will ever own. You can't get your charging system checked out ONCE for less than twice or three times that.
  11. cabwrecker
    1,626
    1,425
    Mar 23, 2012
    Yeah, he should be able to replace just the voltage regulator and not the whole alternator assembly.
