Columbia odometer flashing
Discussion in 'Freightliner Forum' started by Prohemi500, Nov 8, 2016.
  1. Prohemi500
    Prohemi500 Bobtail Member
    30
    Jul 4, 2013
    I have a 06 Columbia with a 14L Detroit. I replaced the seal on the rear of the transmission today and now my odometer is flashing. It reads fine, and the speedometer reads fine but it continually flashes. Only thing I had to do was drop the driveshaft and unbolt the plate on the rear of the tranny to replace the seal. I did attempt to lightly remove the speed sensor, it is mounted on the back of the trans aiming down to the top of the driveshaft , but It was froze and would not budge. I'm going to crawl back under it and check things again, but I haven't heard of this before.. Thanks in advance for any ideas!
  3. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    make sure the yoke is tight and the ring is tight for the speed sensor sometimes they get loose and make these kind of problems also check it the plug is in properly and make sure the wires for speed sensor are good. i personally like to ziptie the wires to the plug being that they go bad from vibration right outside connector.
    Prohemi500 Thanks this.
  4. Verdel
    Verdel Medium Load Member
    599
    135
    Oct 26, 2013
    It flashes because is time for service. You accidentally set up some miles when playing with your odometer and when these miles passed, the odo starts flashing. Most of the Columbia's have this feature.
  5. zivtran
    zivtran Bobtail Member
    22
    4
    Jun 22, 2013
    Did you figure it out?
    I am having the same problem on my Columbia
  6. zivtran
    22
    4
    Jun 22, 2013
    Did you find a fix for this?
  7. Verdel
    599
    135
    Oct 26, 2013
    The fix is: clear your odo setting and set it to another 15k miles or whatever you change the oil or you you can just set to 0. It looks like this "- - - - - -" and will never flash again.
    zivtran Thanks this.
  8. Hulld
    Hulld Road Train Member
    2,884
    6,568
    Oct 19, 2015
    Upstate NY
    Mine did this after I repaired some wiring.
    I disconnected the battery's and it reset everything.
    No problem in two months now.
  9. Verdel
    599
    135
    Oct 26, 2013
    If you disconnect the batteries for 15 min, this works to. :)
