Conestoga walking
Discussion in 'Flatbed Trucking Forum' started by Vanillagorilla323, Oct 18, 2023.
  1. Vanillagorilla323
    Vanillagorilla323 Bobtail Member
    Oct 18, 2023
    I've just recently came into possession of a Conestoga. I love the idea but the biggest issue I'm having is rolling from the back, neither side rolls together. I have to basically walk each h side all the way forward. Is there a way to fix this to make it roll forward together?
  3. Ruthless
    Ruthless Road Train Member
    9,166
    91,023
    Aug 28, 2010
    The City.
    Lube the rollers and tighten the frame
  4. mpow66m
    mpow66m Heavy Load Member
    817
    507
    Jul 6, 2011
    Northeast
    Buy a curtain side w/ buckles,lol.I had the same problem I found out it would only roll from the drivers sd for some reason and mk sure the knobs,if you hv them to tighten the the frame to the rail to prevent rolling are completly loose.
    cke and Vanillagorilla323 Thank this.
  5. Vanillagorilla323
    Oct 18, 2023
    OK I'll ill try both
    mpow66m Thanks this.
  6. Espressolane
    18,652
    116,848
    To expand on what @Ruthless said.
    Check your rollers, make sure they are clean, lubed and the hardware is tight and no damage.
    Check the tracks, clean and no damage.
    Check the frame for loose parts and damage or worse missing parts/pieces.
    Bean Jr., cke and Vanillagorilla323 Thank this.
  7. OLDSKOOLERnWV
    19,113
    288,961
    Reflecting on what @Ruthless mentioned….
    When the frame gets tweaked over time it’s not as sturdy as it is when new, it becomes flexible. You pull on one side and the frame will twist causing the opposite side rollers to bind in track.
    I’ve had the same issue with the tail section of mine, after looking closely I found cracks in the aluminum box tubing the rear frame is made out of…..
