Coolant being ejected from breather
Discussion in 'Experienced Truckers' Advice' started by Gurjap, Jan 3, 2023.
  1. Gurjap
    Gurjap Light Load Member
    57
    11
    Mar 18, 2020
    Hello friends,
    I drive a kenworth t800 2012 with a Cummins isx . The coolant pressure become very high and it begins to forcefully come out the coolant breather. Engine temperature is normal.
  3. D.Tibbitt
    156,861
    Blown head gasket most likely. Join the club. Mine just blew up too
    Rugerfan, JonJon78, tscottme and 2 others Thank this.
  4. Gurjap
    57
    11
    Mar 18, 2020
    Cummins isx 900000km driven 2012, if everything is working fine and just the head gasket is blown, should I get motor rebuild
    Or just change the head gasket.
    austinmike Thanks this.
  5. Goodysnap
    Goodysnap Road Train Member
    3,771
    9,195
    Jul 12, 2017
    Overhaul.
    The root cause of the head gasket failure is likely much deeper than just the gasket itself. Replacing the gasket may correct the issue…..temporarily, but for how long.
  6. krupa530
    krupa530 Light Load Member
    296
    1,140
    Dec 3, 2014
    Orem, UT
    Sorry ace. Can’t thank this. Hope you were near home 20 when it happened.
    D.Tibbitt Thanks this.
  7. 201
    201 Road Train Member
    12,758
    26,251
    Apr 16, 2014
    high plains colorado
    Changing just the head gasket is like taking a shower and putting dirty underwear on. Do it once, take that cruise you've been hankerin' for while the motor is being rebuilt, you and the truck can return at full pace,,,
    D.Tibbitt, ZVar and austinmike Thank this.
  8. cke
    cke Road Train Member
    6,138
    75,567
    Aug 4, 2013
    Colfax Wi
    Today ?????
    JonJon78 and D.Tibbitt Thank this.
  9. W923
    W923 Road Train Member
    1,419
    4,387
    Feb 28, 2022
    If…and I doubt it…there’s no other reason for it to let go other than old age, I would probably throw a new one on and see how much farther I can make it go assuming there’s no other reason for an o/h and the cylinder liners look ok. I would also be doing the work myself so it wouldn’t cost much to give it a try and I wouldn’t be counting on someone else’s judgement for how far to go. If it got me 2-300k more miles it would be worth it in my opinion.
  10. W923
    1,419
    4,387
    Feb 28, 2022
    Possibly could be the air compressor. It’s got engine coolant running through it too. Realistically it’s probably more likely to be the engine but worth checking first
  11. Magoo1968
    Magoo1968 Road Train Member
    2,055
    5,476
    Mar 18, 2021
    St Malo mb
    How long you plan on keeping it and whether there’s other engine damage should play a part in how much you want to spend on it.. your spending a lot on labor as it is so the extra parts might only double the price of repair
