Coolant jacket inserts 3406 c15
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Seancb1234l, Dec 22, 2021.
  1. Seancb1234l
    Seancb1234l Bobtail Member
    5
    Dec 22, 2021
    Texas
    Anyone out there doing inserts in coolant jackets on deck. Just wanting some help getting started doing them.
  3. Roger McG
    Roger McG Light Load Member
    165
    198
    Oct 22, 2016
    western mass
    Please explain coolant jacket inserts. IE location in block, function, etc... I have built many a cat engines dont recall running into coolant jacket inserts.
  4. Rideandrepair
    17,519
    56,765
    Aug 8, 2015
    I think he’s referring to counterbores
    Roger McG Thanks this.
  5. Roger McG
    165
    198
    Oct 22, 2016
    western mass
    My machine shop guy and local cat guru says cut the counterbores deep enough for the thickest counterbore shim. I think its 5 thousandths and you will have perfect liner protrusion and never have a head gasket issue
    black_dog106 and Rideandrepair Thank this.
  6. ProfessionalNoticer
    2,941
    7,858
    Apr 25, 2021
    Any decent machine shop does them. I have a guy that will machine out the corrosion around them and replace with a stainless insert. He'll also do the counter bores and inner chamfers. He's completely mobile and can do it in frame like 90 percent of the time. Many places don't bother with the corroded jackets though because it's such a common issue that's easily fixed using a metallic epoxy like Belzona for a lot less.
    lester and Rideandrepair Thank this.
  7. ProfessionalNoticer
    2,941
    7,858
    Apr 25, 2021
    You've never seen a corroded water jacket in a CAT before?
  8. Rideandrepair
    17,519
    56,765
    Aug 8, 2015
    They used to use thin shims. I don’t know about Cat, but Detroit uses the thick inserts. I think there’s 3 different sizes. I would only go with thick enough for what’s needed, if you get the thickest ones, more than what’s needed, there’s nowhere left to go next time. Best to let a Pro determine what’s needed. Get it right.
  9. Seancb1234l
    5
    Dec 22, 2021
    Texas
  10. Seancb1234l
    5
    Dec 22, 2021
    Texas
    We have always used epoxy, but had a block come in the other day that was done and I loved the way it looked.
    Flint1 and ProfessionalNoticer Thank this.
  11. ProfessionalNoticer
    2,941
    7,858
    Apr 25, 2021
    That looks great. Definitely worth the extra expense if time allows.
