Coolant leak
Discussion in 'Freightliner Forum' started by me myself and I, May 8, 2017.
  1. me myself and I
    me myself and I Heavy Load Member
    735
    312
    Oct 5, 2009
    vernon hills,Il
    On '13 Cascadia with DD15. Looking from underneath I can see some coolant at air compressor. Right at connection with p/s pump. Top of compressor is dry. I don't think it drips from the block, or coming from the front of the engine. Where can it be coming from?
  3. ASE tech/mechanic
    ASE tech/mechanic Bobtail Member
    12
    May 8, 2017
    There are two preformed line that runto the block and compressor.it is no doubt one of them,I have done many of them,there fun to say the least.
  4. ASE tech/mechanic
    12
    May 8, 2017
    If you're an owner opp,with time.high idle engine at 1500,look at the front of the compressor by block and the fro t of the compressor.it is again a pain to see but if you're able to do it,it evolve's draining half of your coolant out and a flat head screw driver.freight liner gets the two hoses mixed up however wich all ways irritates me when I have to tell you guys that when I'm working on your trucks.its a 30min to an hour job for the hose and the hoses just has one snap ring on each end.hope this helps,if all else fails,I'm in az,good luck.
  5. ASE tech/mechanic
    12
    May 8, 2017
    I
  6. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    look for compressor coolant lines one of them has a hole replace both being that they always go bad just need to drain coolant the rest of it is really easy
  7. me myself and I
    735
    312
    Oct 5, 2009
    vernon hills,Il
