coolant leaking from bunk heater?
Discussion in 'Volvo Forum' started by Pmracing, Oct 29, 2015.
  1. Pmracing
    Pmracing Road Train Member
    6,354
    3,178
    Jan 28, 2011
    Arlington Heights, IL
    Is there a shutoff on supply line so the entire system does not need to be drained for service? Local shop is not too knowledgeable on Volvos.
    VNL 64T
    Thanks,
    Mikeeee
  3. AModelCat
    164,584
    Not sure on the shutoff but if they are just heater hoses, you could pinch them off at the engine with a couple pairs of flat nose vice grips while you fix the leak. Hose pincher pliers would work best though if you have them.
  4. DaveLV
    DaveLV Light Load Member
    182
    261
    Sep 18, 2015
    Not unless you installed one..trucks are not equipped with them stock
    Pmracing Thanks this.
  5. DaveLV
    182
    261
    Sep 18, 2015
    Also if you are replacing the heater core in the bunk, they will have to notch the top flange that the bunk rests on to get it out. No other way with out removing the entire HVAC unit which is a pain. Also there a 4 orings that they will need for the pipes. Whole operation is less than 30 minutes to do and that is with cutting the notch.
    Johnny-FlipFlop, KB3MMX and Pmracing Thank this.
  6. Justin Sane
    Justin Sane Light Load Member
    92
    69
    Aug 21, 2012
    don't know about a Volvo but 05 Freightliner Columbia has the shutoffs under the hood. They are in the same area as the shutoffs (heater hoses) that go to the cab's heater core. Should be fairly easily to determine.
  7. dkooi
    dkooi Bobtail Member
    8
    4
    Mar 28, 2013
    There are no shutoffs from the factory as mentioned by DaveLV.
    If your leak is minor (can smell coolant when running bunk heat, but are not losing a significant amount of coolant) you may just be able to tighten the bolt on the hose flange on the bunk heater core, the o-rings can shrink and start to leak small amount onto the heater core. I've found to happen on both the 780 and 730 style trucks. You can gain access by removing the top cover of the bunk heater, the hook-up for the hoses is on top of the heater core. The clean the core, to try to remove the smell, the best you can with some citrus spray cleaner and rinse with fair amount of water. Just tightening the bolt or adding new o-rings may be all you need.
    KB3MMX and QUALITYTRUCK Thank this.
  8. d281833
    d281833 Heavy Load Member
    881
    919
    May 15, 2012
    I've had 2 of these things an 06' and this 12' and both have had to have the bunk heater cores replaced due to leaking. Not sure who's making them for Volvo but they're junk. Trying to get the smell out takes quite awhile especially if it's been seeping for a bit, head ache city.
  9. Pmracing
    6,354
    3,178
    Jan 28, 2011
    The new-ish shop that had never worked on Volvos before has changed three of them in a week and has another scheduled... Hahaha
    Mikeeee
  10. Pmracing
    6,354
    3,178
    Jan 28, 2011
