Coolant level low warning light,
Discussion in 'Ask An Owner Operator' started by feldsforever, Aug 8, 2020.
  1. feldsforever
    feldsforever Road Train Member
    1,453
    1,440
    Nov 22, 2019
    I will try that, how much are you thinking?
    truckdriver31 Thanks this.
  3. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    like inch or so
    feldsforever Thanks this.
  4. feldsforever
    1,453
    1,440
    Nov 22, 2019
  5. D.Tibbitt
    158,143
    Could be the magnet in the tanke is getting stuck. May have to replace the entire surge tank if ur still getting a code or low coolant alarm after replace sensor. Also could be one of the wires in the harness is rubbed thru
  6. Atlaw4u
    Atlaw4u Heavy Load Member
    750
    1,131
    Jun 8, 2018
    Check out Rusty Cracker on Youtube. He recently had the same problem on a Cascadia. He did a quick fix by using a paper clip to jump the sensor and it cleared his issue for now
    Speed_Drums Thanks this.
  7. feldsforever
    1,453
    1,440
    Nov 22, 2019
    I will thanks
  8. Ridgeline
    22,782
    124,712
    Wait.
    I think this sensor is one that can be unscrewed from the tank, if so take it out of the tank and pull the arm up and see if the code clears. If it doesn't then it is either in the wiring or you have a defective sensor, I've had a bunch if them that were just junk and wouldn't work even brand new.
    Your question about checking the oil, I always check it stopped, let it settle for four minutes and check it. If you do it in the morning, before starting the truck, that's the best time.
  9. feldsforever
    1,453
    1,440
    Nov 22, 2019
    I Usally do it Inn the am. But if I'm not on solid ground. Ill Check it when no Find some. Im on a restart now and idling/ apuing. On 50 50 time split. I did not know if the apu. Affected the. Oil level.lk
    Gotta ask the boss to make sure he will replace the coolant first. If I just do it. Its on my dime. Will let you'll know
