Coolant tank
Discussion in 'Volvo Forum' started by shim2000, Sep 16, 2024.
  1. shim2000
    shim2000 Bobtail Member
    24
    Looking for opinions. At cold engine, should my coolant level be at the minimum or maximum? I've seen mixed messages on Facebook Group Volvo Truck Masters
  3. Rugerfan
    Rugerfan Road Train Member
    7,725
    39,518
    May 3, 2011
    Redding,CA
    Ideally it’d be somewhere in the middle
  4. Lav-25
    Lav-25 Medium Load Member
    570
    906
    Mar 31, 2018
    What he said
  5. shim2000
    24
    I'm just curious if coolant level is at maximum at cold engine,, if it affects the life of the tank as in too much pressure? Or is that bogus analogy?
  6. Diesel Dave
    9,635
    32,554
    Jan 20, 2010
    Hesperia, Ca.
    I feel mine up to the maximum level when cold. And no need to top as of yet.
    Lav-25 Thanks this.
  7. Lav-25
    570
    906
    Mar 31, 2018
    The thing about resivors is they are the visual of what is happening with the inside of the engine , along with the oil. In the case of the res, it provides additional water when needed , and storage for when it isn't .( when it 115 degrees out and your engine is getting a little hot , it uses a little bit more , and reverse in fall -winter . ) the space from the bottom of the cap to the full line is a safety measure so that the fluids have a place to go instead of a bypass / overfill tube .
    Rideandrepair Thanks this.
  8. Rideandrepair
    17,548
    56,859
    Aug 8, 2015
    Minimum cold. Maximum hot. If there’s a few inches or? between max mark and top of tank, You can get away with adding little extra, Maybe half of the difference. Don’t want to overfill it and have the hot expanded coolant crack the plastic tank.
