Coolant
Discussion in 'Trucks [ Eighteen Wheelers ]' started by gerardo1961, Aug 16, 2010.
  1. gerardo1961
    gerardo1961 Road Train Member
    1,746
    613
    Feb 21, 2010
    Miami
    I have a question about coolant ,is the coolant to change I hAve 559 k ,when yes what is the best brand for a coolant is A cat-c 13
  3. bender
    bender Road Train Member
    2,105
    1,361
    Jul 20, 2010
    Don't Kid Yourself
    Cat Cool extended life coolant.
  4. gerardo1961
    1,746
    613
    Feb 21, 2010
    Miami
    In what place I find this coolant,in same truckstop Ta, petro .....
  5. gerardo1961
    1,746
    613
    Feb 21, 2010
    Miami
    And is the coolant to change ,and is this. A special brand
  6. bender
    2,105
    1,361
    Jul 20, 2010
    Don't Kid Yourself
    This is Cats oem coolant. It comes premixed ready to use straight out of the jug. For best pricing, purchase at a Freightliner or International dealer or similar, not from a truckstop.
    gerardo1961 Thanks this.
  7. rockrawlin
    rockrawlin Bobtail Member
    47
    20
    Sep 5, 2008
    Chico, CA
    I just bought some on the Cat coolant at KW. It was just under 10 bucks a gallon. Don't forget to add the extender at 300k miles.
  8. lego1970
    lego1970 Medium Load Member
    504
    165
    Oct 10, 2008
    Blue Springs, Missouri
    You can buy test strips pretty cheap. That will tell you the PH balance, freeze point and for the most part, the overall condition of your coolant. I still always flush mine out (non extended life coolant) every couple years regardless of what the test strips say because I always worry that some of the crude will not be acidic or caustic enough to change the PH, or have a similiar PH to what is considered normal. Also it's good to flush the radiator out on the outside. I bought a cheap wand that attaches to my garden hose and put about a 60 degree bend in it so I could flush the radiator from the engine side outward. Be carefull not to bend your fins.
    I'd be curious how often others change out their coolant.
  9. gerardo1961
    1,746
    613
    Feb 21, 2010
    Miami
    What is the price to pay for a coolant change with the coolant and how many gallons go inside
  10. gerardo1961
    1,746
    613
    Feb 21, 2010
    Miami
    Whe iam drive in the hills my temp go very high 230 gr for this I think to change the coolant meaby the Copland is bad the fan works before never I have troubles with the temp only now
  11. lego1970
    504
    165
    Oct 10, 2008
    I can't remember since it's been awhile and I also used to do it myself, so I don't know what they charge at a shop. I would take a plastic tote like you buy at Walmart to store food, or whatever and place it under the drain. I would pump the antifreeze out of the plastic tote and into a 55 gallon drum as it was draining since the plastic tote only held 5 gallons or so. Then I would take a garden hose and flush out the radiator for several minutes. Then fill it back up with filtered water and pure antifreeze. Seems to me like it was cheaper that way, then buying the pre-mixed stuff. I wanna say it took about 20 gallons on a 12.7 detroit? I would get rid of the old antifreeze every winter from the guy that would buy my used oil. I never had any radiator or water pump issues, but I'm not garunteeing my method was correct.
