Coolant
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Stormbk09, May 14, 2014.
  1. Stormbk09
    Stormbk09 Bobtail Member
    19
    Mar 15, 2014
    Bonner Springs, KS
    I have a. 07 Pete 387 and I put at least a gallon of antifreeze each week. Is this normal I have 800 K miles any ideas? Thank u
  3. maggard359
    maggard359 Medium Load Member
    476
    413
    Nov 20, 2013
    Florida
    It isn't normal unless you are overfilling. If you overfill in tank it will push it out the overflow tube. I don't know how to tell you the full mark I usually just eye it maybe an 2 inches below neck. If you are not overfilling it you have a problem.
  4. Heavy Hammer
    Heavy Hammer Road Train Member
    1,184
    5,890
    May 1, 2013
    In purgatory
    No it is not normal.
    EGR cooler, head gasket, cracked head, cracked block, worn/shifted liner, water cooled turbo, doser injector failure, etc. Are you pressurizing the cooling system at all?
    Not enough information...engine make, blah, blah, blah...with a little more info we can maybe point you in the direction to start looking...
  5. Stormbk09
    19
    Mar 15, 2014
    Bonner Springs, KS
    Thanks. My truck runs absolutely fine. The oil looks fine as does my coolant. I have not found any puddles under the truck and can't find evidence of any leaks also my water temperature is within normal range
  6. mattbnr
    mattbnr Road Train Member
    1,950
    837
    Aug 19, 2010
    Tama,Iowa
    No that's normal for any vehicle.
    Stormbk09 Thanks this.
  7. Stormbk09
    19
    Mar 15, 2014
    Bonner Springs, KS
    It's normal to use coolant? The truck burns it up ?
  8. Heavy Hammer
    1,184
    5,890
    May 1, 2013
    In purgatory
    No it's not normal, what engine do you have?
    Does your truck have a DPF or not?
    The majority of these will not leave puddles, and your truck may well be running fine, but the problem may not have shown itself yet but may be slowly building into something bad
  9. maggard359
    476
    413
    Nov 20, 2013
    Florida
    No. It isn't normal to lose coolant. You won't always see the leak. It could be burning it thru exhaust. I have a 1985 truck and never add coolant. You could have overfilled and when it built pressure it let it out the overflow thus not leaving a trace as you were driving. I would bet the farm somewhere you have a leak.
  10. Stormbk09
    19
    Mar 15, 2014
    Bonner Springs, KS
  11. Heavy Hammer
    1,184
    5,890
    May 1, 2013
    In purgatory
    I'm not real good with pre DPF Cats, but with no puddle traces, I'd lean towards injector tubes, head gasket, cracked head, liner issues...
    I'd advise an oil sample to check for the presence of coolant in the oil. If yes, I'd lean toward liner issue. If no, lean towards head or head gasket...a good shop should be able to point you in the right direction with a quality sample analasys.
