cooling system problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by tonher, Dec 3, 2015.
  1. 1johnb
    1johnb Medium Load Member
    542
    405
    Jun 13, 2012
    New Paris Ohio
    My money is on the head gasket also I have seen and done way more than I want to remember. It is a good idea to replace the head bolts also
  3. DaveLV
    DaveLV Light Load Member
    182
    261
    Sep 18, 2015
    You can put the cart before the horse and go straight for the head gasket. OR, diagnose the problem find the root cause and repair it. You will be some sort of pist off if you tear off a head, put it back together and still got the same problem. You guys bag on dealers for throwing parts at a truck and half have said head gasket. Only one said diagnose. I have customers come into my shop everyday wanting to replace a part. Usually an expensive component because they saw a YouTube video or their buddy had the same problem and he did this. Turns out it was a $90 sensor and fixing a boost leak better than a $3500 turbo. Might just be a head gasket. That's why I mention the tester from Napa. But I still think it's better to rule out an issue than rrt and throw parts at it and hope you fix it.
    mhyn Thanks this.
  4. tonher
    tonher Bobtail Member
    38
    16
    Jul 30, 2008
    Phoenix, AZ
    OK, what you say makes sense. I was just getting confused because some guys were saying just remove the air lines off the top of the compressor . Yes The bubbles start after a few minutes like when the motor starts to get worm then the bubbles start. thanks for your patience and help.
    tony
