crankcase filter
Discussion in 'Trucks [ Eighteen Wheelers ]' started by walter wells, Apr 8, 2014.
  1. walter wells
    walter wells Bobtail Member
    5
    Mar 11, 2014
    I would like to know the location of the crankcase filter is on my 2006 isx..Doe's anyone know???
  3. Heavyd
    Heavyd Road Train Member
    7,824
    6,274
    Feb 4, 2009
    2006 will be a CM870. No filter on those. Just the blow by tube that goes from the top front cover down to around the starter.
  4. logtrucker25
    logtrucker25 Light Load Member
    70
    9
    Jul 27, 2009
    northern CA
    Heavyd, how often should you change the crankcase filter on a cm871?
  5. walter wells
    5
    Mar 11, 2014
    THANKS..Now I will find something else wrong with my truck.
    Cat sdp Thanks this.
  6. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    This crankcase filter thing is not only something that the newer diesels need. Due to the many issues that plague the GM small blocks nowadays, many of us are putting Oil separator units in the PCV line of our gasser engines. Unbelievable the amount of condensation, oil, and junk goes thru the PCV line to the intake. In 10,000 miles, my PCV catch can has captured about half a quart of that junk in my 5.3L small block. One can only imagine the amount of oil that gets caught up in the closed crankcase system on these newer heavy diesels.
    Heavyd Thanks this.
  7. Heavyd
    7,824
    6,274
    Feb 4, 2009
    Yes, you are right. It is amazing.
  8. Heavyd
    7,824
    6,274
    Feb 4, 2009
    Cummins recommends every 125,000 mi or 3000 hours.
    logtrucker25 Thanks this.
