Cruise control
Discussion in 'Peterbilt Forum' started by spindrift, Jan 3, 2022.
  1. spindrift
    spindrift Road Train Member
    3,234
    12,915
    Dec 2, 2014
    Texas
    I was idling. One minute I was on high idle, turned it off when I moved the truck a couple feet and now it won't come back on. Any ideas?
  3. 062
    062 Road Train Member
    6,326
    33,964
    Oct 20, 2013
    Most likely clutch switch or brake switch. Try bumping the clutch a few times and pull up on it. Same with the brake,and make sure the hand valve is all the way up.
    Oxbow, Puppage, Rideandrepair and 3 others Thank this.
  4. spindrift
    3,234
    12,915
    Dec 2, 2014
    Texas
    @062 that was, without question, the easiest fix I've ever had the pleasure of making. Stomped on both the clutch and brake pedals at least five times and all was good. I know there's a brake pedal piston that I should grease. Is there something similar associated with the clutch switch?
    Oxbow Thanks this.
  5. 062
    6,326
    33,964
    Oct 20, 2013
    It would be best if you knew which one did the trick. Brake plunger and pivot pin needs cleaning and oiling.
    Clutch rods have heim joints,you may have a grease fitting on one of those.
    I use air tool oil and a eye dropper.
    spindrift and Oxbow Thank this.
