Cruise control
Discussion in 'Ask An Owner Operator' started by Spyro2112, Jun 9, 2018.
  1. Spyro2112
    Spyro2112 Medium Load Member
    623
    432
    Mar 17, 2018
    07 freightliner detroit, changed speed sensor, clutch sensor, still no cruise, jake, cruise works with break on, what next, help
  3. kemosabi49
    10,968
    47,850
    Jan 13, 2013
    SW Arkansas
    Are your brake lights on? Switch for your break lights malfunction will keep your cruise and jakes from workiing.
    Oldironfan Thanks this.
  4. Dan0
    Dan0 Bobtail Member
    13
    11
    Jun 11, 2018
    Down south and all around
    I had that problem on a old freightliner classic, it was an air switch with 2 wires on it. Located back behind the dash panel. I could hear it hissing through the terminals. Its supposed to normally closed switch but mine stuck in the open position which made the cruise think I was applying the brakes... 20 dollar fix... I hope that's all it is for ya
  5. RustyBolt
    RustyBolt Road Train Member
    2,073
    3,334
    Feb 21, 2015
    Bement, IL
    You didn't mention the cruise control switch itself. Any idea if it is working properly?
  6. Dave_in_AZ
    421,941
    Clutch pedal return spring intact? It pulls the clutch pedal all the way up and closes a micro switch that disables cruise.
    Or perhaps that micro switch, but usually it's a broken clutch pedal return spring.
