Cummins 2015+
Discussion in 'Trucks [ Eighteen Wheelers ]' started by HighwaySuperTramp, Feb 21, 2017.
  1. HighwaySuperTramp
    HighwaySuperTramp Medium Load Member
    316
    349
    Feb 8, 2015
    I keep reading threads on here about Cummins VS Paccar but they are always about the older motors 10-13.
    Anyone have any experience with the newer ones? I'm a Canadian O/O with a 485 mx looking to get a new truck this year. Either Kenworth or Pete pulling reefer. I'm wondering which would be the most reliable and be the better spec. The 500 or 510mx or the 500-550 cummins. Or would the 550 be too much and I would have to worry about carbon packing.
    Sadly glider kits are illegal in Canada so I can't go that route. Otherwise it would be a 12.7 550hp Detroit. Or a 650 6nz.
    Thanks in Advance all.
  3. AModelCat
    164,173
    Since when are gliders illegal in Canada? I believe there are a few Canadians on this forum with gliders.
  4. HighwaySuperTramp
    316
    349
    Feb 8, 2015
    Can't get them anymore to my knowledge. Federal law changed. Now the engine has to meet the emissions requirements of the year of the chassis, not the engine. Only way to do it left is very very expensive to my knowledge.
  5. Steve62
    Steve62 Light Load Member
    170
    98
    Mar 5, 2015
    Northern BC
    Glider kits are not illegal in Canada. Inland Prince George will sell you one.
    You have to have a donor truck with the motor and tranny what ever year the donor truck is that is the year your glider will be registered as.
    HighwaySuperTramp Thanks this.
  6. Cat sdp
    Cat sdp . .
    21,270
    75,928
    Apr 8, 2012
    Orion's Belt
    I'd do cummins over the Mx , just because of more repair shops to pick from.....
    P.S. Glider is the way to go.
  7. tax
    tax Light Load Member
    119
    110
    Nov 29, 2013
    I never drove mx but I have 15 cummins no problem so far. If you don't idle and do maintenance you should ok the 500k after it will start getting costly replacing old emissions parts
  8. Christ Major
    Christ Major Bobtail Member
    4
    I have a cummins isx and It runs well. Whats the big deal with one engine over the other anyways. From what I understand its really all preference. I've driving all engines I think the cummins and detriot are fair.
  9. Christ Major
    4
    So the glider kit is all mechanical? No computers and such.
  10. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    Last I knew a 60 series and 6nz both have computers. No egr, dpf, def though. Id take an isx over the paccar anyday. I have experience with dd15 and isx 12 & 15. Id pick the isx over the dd. (and the isx just sounds cooler)
