Cummins Engine Identification help please
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Binderdavemays1, May 28, 2025.
  1. Binderdavemays1
    Binderdavemays1 Light Load Member
    169
    80
    Jul 30, 2024
    Luebbering Mo
    I have to go to bed so I can get up at eight tonight and go back into work so it’s no rush. I mean whenever you find out is fine because like I said, I wanna pull the oil pan off the new engine and at least put a rear main seal and the oil pan seal back on it gasket and look at everything as much as I can before I transfer the engines out and then I got a buy a clutch and throw out bearings and all that stuff because I wanna put all that new when I put it back in together.
  3. SmallPackage
    5,757
    18,457
    Dec 20, 2019
    Marion Texas
    I’ve got a dozen old pumps on a shelf that the tags on them do not match the calibrations of what they came off of. Unless it is still 100% original Those tags generally mean nothing over the years of tinkering, fixin’ and swapping these engines get. Ive got a sc 250 non turbo with a bc pump on it. Tagged for a formula 350. Lol.
  4. Binderdavemays1
    169
    80
    Jul 30, 2024
    Luebbering Mo
    You guys can continue on with the debate and the opinions and the information and to help trust me. I’ll read it all when I get up tonight again I can’t thank you all enough
    the bummer part of all this is is a so hard to find a Cummins mechanical mechanic.
    I know they’re out there, but they’re retired or they just don’t wanna mess with it anymore. I wish I could find one that I could pay to teach me everything they know.
  5. Binderdavemays1
    169
    80
    Jul 30, 2024
    Luebbering Mo
    Also, if anybody has a cool inexpensive idea on a cradle/ stand that I can build to put this small cam on in my shop so I can roll around and work on it and yet keep it out the way
  6. OLDSKOOLERnWV
    19,051
    287,639
    Think CPL 695 is the 400 Magnum small cam engine from what little info I found. I don’t know if the parts are still available but sure they are somewhere. Call around and see if that CPL comes up… be your next bet versus a good 350 with pump work and injectors. Good pump will surprise you…
    BoxCarKidd Thanks this.
  7. Binderdavemays1
    169
    80
    Jul 30, 2024
    Luebbering Mo
    Both are CPL160 I believe
  8. OLDSKOOLERnWV
    19,051
    287,639
    Yes but… the small cam 400 was CPL 695 from what I’m finding,
    So, if you ordered a rebuild kit for CPL 695 you could build it directly as a 400 instead of a hot 350….
  9. OLDSKOOLERnWV
    19,051
    287,639
    Keep in mind you may have to change the offset key on the camshaft gear too to change the timing.
    You don’t just add fuel and create a 400 engine, there’s a lot involved….
    Binderdavemays1 Thanks this.
  10. OLDSKOOLERnWV
    19,051
    287,639
    Pump shop called back and confirmed your pump is calibrated for a 350….
