Cummins ISB codes 391&364
Discussion in 'Trucks [ Eighteen Wheelers ]' started by kgktm, Nov 29, 2011.
  1. kgktm
    kgktm Bobtail Member
    49
    Jan 26, 2011
    07825
    2002 mt 45 scanned with insite.trouble codes 115,391,364,234,373,369,434,362.While truck was running truck shut off and 391 and 364 became active.
  3. Heavyd
    Heavyd Road Train Member
    7,753
    6,188
    Feb 4, 2009
    391 shows fuel shut off valve,
    364 shows fuel pump control module.
  4. kgktm
    49
    Jan 26, 2011
    07825
    is that on the vp 44 pump or the ECM
  5. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    As I remember '02 engine has Bosch VP44 fuel pump. and it is a big problem
    391 is the bad fault code. There is comntrol board on injection pump. There are two power FETs on it. They are cooled with fuel flow. And if you pump in fuel with starter (when you ran out fuel) it may go bad.
    364 is ECM Pump commumication fault. may be bad wiring.. may be bad pump. engine wont starting.
    115 - engine speed problems. may be bad wiring/sensor ore may be engine runs rought ore stalls.
    234 - engine overspeed. usually related with pump going bad, engine selfrevs and stalls....
    373 - fuel pump used shut off valve to stall self reveng engine (if code is stored).
    369 - ECM - pump sihronisation fault.... it is bad
    434 - kl. 30 low voltage (hah, you tried to start engine till battery was low)
    362 - fuel metering circut went bad
    VP 44 is expencive and very difficult to fix, remove and install injection pump, but it is very accurate and was ready to E3 and EPA 2003 emissions.
    Was used on MAN L series engines and on Cummins ISB. But becouse of many problems MAN and Cummins switched to Common rail with MS6.4, MS7 and CM570 control units.
    There are two workshops in Ukraine, where they rebuld VP series pumps. Equipment is expencive. Parts too. So trucks with VP pumps are much cheapper here.
    So look for Bosch workshop. Cummins and MAN dealers can change pump with new
  6. kgktm
    49
    Jan 26, 2011
    07825
    i have the vp 44 power relay powered with a toggle and the ground paralleled.So the pump should be powered up all the time could the the fuel pump fuel solenoid fail even when seeing 12v constant with out the ECM controlling it.
  7. Heavyd
    7,753
    6,188
    Feb 4, 2009
    Sorry, we don't get into these engines, no one around here really has any.
  8. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    I would say the same about MAN L2000. VP44 is the nightmare.
    It is overpriced!
    So look for later engines becouse later Bosch discontinued VP pumps and they introduced CRD for small truck with MS7 ECM, so later all Cummins ISB, ISL, ISF, MAN TGL, IVECO and other got Bosch CRD system.
    Yep, I do not like CRD, but it is much better, more precision, more reliable and less expencive then VP series pumps
  9. bliskin12
    bliskin12 Bobtail Member
    It is a emergency shut down relay. Either there is a condition to shut it down, 9 times out of 10 I have seen that relay goes bad, and often. Driver side of engine, relay from ecm. Make sure voltage, If 24v napa ect. will tell you they have a match except 12v.
