Cummins ISX 500
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Koolk, Apr 18, 2013.
  1. Koolk
    Koolk Bobtail Member
    42
    7
    May 19, 2011
    Richmond, BC
    Hi guys, i have a 2006 KW with Cummins ISX. Recently I seem to have a coolant loss issue.
    The Coolant was low and could not find any leaks on outside anywhere. Topped up Coolant and ran the Truck for a few days. When working it hard it blew coolant out of Radiator overflow port. Then low coolant warning comming on!
    Thought it was the cap so we replaced it. Also replaced coolant sensor.
    You can smell coolant when the fan kicks and also see some spray against hood. ( the overflow drip line is missing).
    Any help appreciated cant seem to put a finger on this one.
    History of Truck is Head Gasket 3 years ago. Egr Cooler , EGR and Turbo 2 years old!
    Seems to pull good and runs smooth! Just tried another new cap 15psi, still same!
    The resorvoir is not empty just makes it low enough to trigger light! Thanks.
  3. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    EGR cooler is the most likely culprit. Check that first.
  4. Koolk
    42
    7
    May 19, 2011
    Richmond, BC
    Ok, gonna have cooler tested
  5. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    Check if you have eat while on idle it could be a head issue like a cup or gasket maybe even the air compressor run a 1/4 air hose to the air compressor shut off that way it does not work and check it out after a bit and see if its making any pressure in the coolant
