Cummins ISX Check Engine Light and Codes
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Makeajump, Jul 3, 2019.
  1. Goodysnap
    Goodysnap Road Train Member
    3,771
    9,195
    Jul 12, 2017
    You mean NOX sensor.........Dont see the connection to a charging or voltage issue with a NOX sensor change.
    I would be starting with battery check and connections clean and tight. Were they disconnected for service? Should not have been needed.
    spsauerland and Makeajump Thank this.
  3. Makeajump
    Makeajump Medium Load Member
    443
    363
    Apr 19, 2014
    Texas
    No were not disconnected but mechanic sees low voltage on 2 after charging so we’re getting 2 new ones to see if it will solve the problem.....
  4. Makeajump
    443
    363
    Apr 19, 2014
    Texas
    4 new batteries Problem Solved....Not the first time I’ve had dead batteries after an ECM Data extraction.......
