Cummins isx information
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Rockycoon, Jan 16, 2017.
  1. Rockycoon
    Rockycoon Bobtail Member
    46
    9
    Apr 18, 2016
    I'm looking at buying a 09 pete with a Cummins ISX. I'm trying to figure out what the HP and Tq can be turned up to. I have the engine serial number but don't know where to look up the information at
  3. bowhunter67
    bowhunter67 Light Load Member
    283
    549
    May 28, 2016
    rush city mn
    Its on the driver side of the valve cover,And with that 09 you are asking for trouble with the emissions. I had an 09 t2000 and spent about $12000 on it in a month and a half from the emissions until i sold it.
    thejackal Thanks this.
  4. Rockycoon
    46
    9
    Apr 18, 2016
    I have the number. Just don't know who/where to look up specs. Plan on cleaning emissions when I buy it. Truck has to be within 10 yrs where I'm going with it so I'm stuck with emissions
  5. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,212
    Jan 7, 2013
    You'd be better off getting a little newer truck with SCR. SCR engine run less EGR and have less EGR and regen problems. As far as uprating it, call a Cummins dealer with your ESN and they'll tell you. Or post your CPL # and maybe someone here has access to tell you.
  6. bowhunter67
    283
    549
    May 28, 2016
    rush city mn
    If you can afford it go with something newer than a 2012 because any of them between 2008 and 2012 had nothing but problems.
  7. Rockycoon
    46
    9
    Apr 18, 2016
    Thanks for the help
  8. boneebone
    boneebone Road Train Member
    2,297
    2,372
    Mar 13, 2009
    The 2015+ Cummins ISX15 CM2350 is the most improved version.
    Like other Posters stated, stay away from the earlier ISX15 motors, they have alot of problems.
  9. hellpatrol
    hellpatrol Light Load Member
    221
    172
    Apr 22, 2013
    here's a site that was given to me. you need the info off your data plate on the engine. I took 3 pics of mine and it was a big help. Once you enter your info it gives you ALL the info about your engine.
    https://quickserve.cummins.com/info/index.html
    trucker3205 Thanks this.
  10. Rockycoon
    46
    9
    Apr 18, 2016
  11. hellpatrol
    221
    172
    Apr 22, 2013
    You are welcome sir....
    Hope it helps.
