Cummins isx timing
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Electromechanic, Apr 16, 2021.
  1. Electromechanic
    Electromechanic Bobtail Member
    6
    How do I know my timing is correct ?
  3. AModelCat
    164,547
    Why do you figure its wrong?
  4. Goodysnap
    Goodysnap Road Train Member
    3,771
    9,195
    Jul 12, 2017
    The ECM knows its in time. If not it throws a fault code.
    The CM 870 and 871 are a tad more detailed than the newer commonrail engines due to the fact that they can be dialed in by valve and injection timing. But for the most part if its not within a cerain window it will do the same.
    spsauerland and Dave_in_AZ Thank this.
  5. Electromechanic
    6
  6. Electromechanic
    6
    When I insert the wedges into both cams and set timing and then rotate to A mark which valves should be adjusted first ?
  7. Electromechanic
    6
    Because after I removed my wedges and rotated to mark A which cylinder must be adjusted first ?
  8. QUALITYTRUCK
    1,819
    1,783
    Jun 14, 2009
    romulus,mi
    "A" will be cylinder #1 or #6. "B" will be #2 or #5 "C" will be #3 or #4. To know if you are #1 or #6 when on "A" look at the injector rocker. Whichever just started it's downstroke is the correct cylinder. The intake and exhaust valves should also be completely closed. After determining that, follow firing order 1,5,3,6,2,4
    Heavyd, haycarter, spsauerland and 3 others Thank this.
  9. Electromechanic
    6
    I am confused whether I am at tdc 1 or 6 when I am inserting my wedges
  10. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
    I don't understand what you trying to do. Did you use crank pin and wedges to set timing?
    Go to cummins quickserve.com for manuals.
    Heavyd and baha Thank this.
  11. Goodysnap
    3,771
    9,195
    Jul 12, 2017
    You do not set valve lash with the engine pinned and wedged, you set the front gear train lash first. Then Bar to "A" and start with 1 or 6 whichever valves are closed. Follow the order as @QUALITYTRUCK said.
    QUALITYTRUCK and spsauerland Thank this.
