Cummins ISX
Discussion in 'Freightliner Forum' started by zaheerkarim, Oct 3, 2013.
  1. zaheerkarim
    zaheerkarim Light Load Member
    73
    Jun 21, 2011
    Malawi
    Hello,
    I have a Freightliner FLD with a Cummins ISX engine. It suddenly has the Engine Check light on once it is started, and a very slight misfire. Can you please help me on how I could diagnose what the problem could be. It is the first time I have owned a truck with that engine and I don't have a clue on what to check.
    I will appreciate all suggestions.
  3. Thad2777
    Thad2777 Bobtail Member
    6
    Change Fuel filter
  4. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,212
    Jan 7, 2013
    Get the flash codes.
  5. zaheerkarim
    73
    Jun 21, 2011
    Malawi
    How do I get the flash codes?
  6. GrapeApe
    2,215
    2,212
    Jan 7, 2013
    There is a diagnostic switch somewhere. It's usually on the dash or down low by the data link connector.
  7. Blind Driver
    Blind Driver Road Train Member
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    I was told the codes can only be pulled with Insight :shrug:
  8. GrapeApe
    2,215
    2,212
    Jan 7, 2013
    Sometimes it's under the dash near the data link plug. I have yet to see a Cummins without one (ones that support flash codes that is). Newer ones do not support flash codes because they display codes right on the dash, so no need for flash codes.
  9. zaheerkarim
    73
    Jun 21, 2011
    Malawi
    I have changed the fuel filter but the Engine Check is still on. I have seen the diagnostic switch on the dash, I have tried switching it on and off but nothing happens. Can you advise how I go about this switch to get the codes.
    baha Thanks this.
  10. Thad2777
    6
    Hook If Up T InsiteMost Dealers Have it
  11. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    look under key 4 it with ENG. off key on. or some cruz. switch up push speed switch up. count flash.
