(Please bump to appropriate thread If this One isn’t applicable)
2013 ISX 3 550 cm2350 20265 hrs
Hey guys n gals. I’m searching for some opinions or “I know the problem“
Recently I’ve been experiencing A respectable shake under engine braking. It noticeably starts around 1600 RPM. All the way down to 1200. When my manifold pressure climbs up above 25psi and oil temp is 230-240, loaded or not.
If I get my oil cool down to 220 or less, it almost disappears.
I’ve got three stages for the jake and can feel it high and medium setting.
Any suggestions or insight would be appreciated.
Thx much
Cummins Jake Shake
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Castorized, Aug 26, 2020.
There is an update to the ecm to reduce engine brake vibration. If that doesnt work you will need to replace all 6 jake brake rocker arms.
650cat425, BoxCarKidd and spsauerland Thank this. -
I actually ended up poppin the cover off the other day, found 2 jake rockers with sooo much play on the shafts... betcha 50$ ya couldn’t build enough pressure with molasses to keep them from ratteling
Really? This isnt normally a spot you would find excessive play. What did you end up replacing? Were the valve rockers worn just as bad? If the top end recieves the same oil flow they should be all worn the same.
I would make sure to follow the rocker installations procedure and checking end gaps while torqued.
Thanks for updating with your fix.
