Cummins M11 Celect Issues
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by High Stepping, May 14, 2024.
  1. High Stepping
    High Stepping Light Load Member
    52
    25
    Oct 29, 2020
    I’m working on a M11 Celect Cummins in a toter home. It had intermittent issues and then just wouldn’t start. We believed it to be an ecm issue, so that was replaced. Then it would start and run above 750rpm with a slight miss, but won’t idle. The owner had previously tried to get it going by changing the cam and coolant sensors. Any ideas what’s going on?
  3. OlegMel
    OlegMel Medium Load Member
    433
    728
    Apr 8, 2023
    Sounds like a timing issue if it runs on higher rpm but won’t idle. Specially if the cam was replaced
  4. nwshippers
    nwshippers Bobtail Member
    I am have a same kind of issue runs for 6 hours (start and stop) then while driving it will suddenly go to idle and shut down. let it sit and it will start and run for a bit. not throwing or storing any codes. I have replaced cam sensor and updated wiring harness. fuel pressure and vacuum are all within parameters. any suggestions of where to look would be greatly appreciated
