cummins m11
Discussion in 'Trucks [ Eighteen Wheelers ]' started by BanditTrucker, Sep 16, 2013.
  1. BanditTrucker
    BanditTrucker Light Load Member
    256
    61
    Nov 24, 2011
    KS
    friend looking to buy a fl columbia daycab its a 2001 with a m11 and 10 spd, single axle.
    its local work (no hills) but heavy 70k how does this engine do in the long run, how much do they last.
    how do these smaller engines(m11, ism, c12, mack 330) do when hauling these weights will u get bad mpg?
    kinda hard to find a big engine on a daycab
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    reliable, good MPG but gutless. with 70K LB of gross weight wpuld run but slow
  4. o/otony
    o/otony Light Load Member
    190
    49
    Dec 25, 2012
    What's the horsepower?
  5. T800H
    T800H Medium Load Member
    608
    296
    Apr 2, 2010
    The Keys
    yea what's the hp, if geared properly, no problems reliable good mpg and powerful for a small block, I'll take the M11 or L10 over small Cats or Macks.
  6. Cattletrkr
    Cattletrkr Bobtail Member
    20
    5
    Aug 1, 2013
    you're friend isn't looking hard enough. All kinds of 400+hp single axles out there. Lots of MBE's and Detroit 12.7l. I've been trying to find one with an 11.1, but they almost all have 12.7. I know that's not "BIG" but it's a fair amount bigger than an M11.
    I drove an M11 the other day for the first time. Grossed around 75K. Don't know the hp rating but it wasn't enough. I'm used to a series 60 11.1 hauling 80K grain truck so I know what slow is. The M11 was slower. With the grain truck I've always thought I'm the slowest guy on the road. Not so anymore. M11 are underpowered for 70K+.
    At least that's how I see it from my whopping 1 DAY driving one.
    Take it FWIW.
    Jake
  7. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    I used to drive 9800 and ERF with M11. Good for European tint trailer with light load
  8. o/otony
    190
    49
    Dec 25, 2012
    if its a 385 hp or over you will be ok.
  9. bowtieboy77
    bowtieboy77 Light Load Member
    274
    82
    Aug 16, 2013
    Southern, Ontario
    Well you got two things against the truck to heavy haul. The smaller cummins engine hooked to a ten speed. Don't get me wrong it will pull it as long as you are patient. My old boss had a 96 flattop freight with m11 and a 10 speed and it long hauled an equipment float. It did the job, good fuel milage and held togeather it just didn't get going and pull the hills as nice as his higher hoarse trucks with 13 speeds. If you buy it knowing this you won't be disappointed when you start running it.
  10. Crimedogg82
    Crimedogg82 Bobtail Member
    7
    I’ve got an m11 in my 97 Volvo 10sp Would it be good for haul 38,000 or less Over road
  11. Crimedogg82
    7
    M11 is it good for road pulling light loads I dare 38000
