Cummins N14 Help
Discussion in 'Trucks [ Eighteen Wheelers ]' started by wish~bone, Jan 20, 2010.
  1. wish~bone
    wish~bone Bobtail Member
    24
    14
    Jan 5, 2010
    VA
    I Have a friend with N14 plus rated at 500hp and it get poor fuel miles and don't pull good at all. Although he wish he had a cat like me but I figure I would throw this out here to see if anyone can help with this or what can he do get get more power and fuel miles.Thanks any suggestion :biggrin_2553:
  3. lowbudget
    lowbudget Medium Load Member
    428
    110
    Apr 12, 2008
    Bismarck, ND
    when was the last overhead run?
  4. wish~bone
    24
    14
    Jan 5, 2010
    VA
    I'm Not for sure but I think it was about 4 months ago. To be honest I think it is the way ecm is set up and it is a 10spd automatic. It pulls better with a loaded trailer than a empty.
  5. truckfixinsob
    truckfixinsob Bobtail Member
    8
    Jan 21, 2010
    If the truck has an automatic I would have to say there is a lock up problem with the torque converter, thats why it pulls better loaded than empty. It also explains low fuel mileage an power. The N-14 is a very efficient engine. It should pull rite with a cat and get better fuel mileage doin it.
  6. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    Well, if it is an N14 it is at least 10 years old, might just be tired!
  7. williamdecker
    williamdecker Bobtail Member
    30
    May 1, 2010
    St. Louis, MO
    Have you checked the charge-air-cooler? A leaking charged air cooler will cause you to loose fuel economy. Also, if your CAC is leaking and you have a pyrometer, you will see high exhaust temps.
  8. JohnP3
    JohnP3 Road Train Member
    1,594
    684
    Feb 21, 2010
    Rock Creek B.C. Canada
    What he said first, If you have low boost it will cut back on the fuel, Is the throttle pedal going to full travel, then see if it is sucking air in to fuel, what is the fuel pressure, what is the intake fuel restriction, could be a bad filter, collapsed hoses or plugged ECM cooler plate. Check the return fuel they do have a problem with allowing combustion back into the fuel system, Do a cylinder cut out test, you can just unplug them they will not log a code, then if there is a problem injector is it the injector or the pass threw connector. Check the air filter, clean the housing before you put it back in. Inspect the turbo for damage, on the compressor and turbine side. Was the valve set done properly? Just a thought!
  9. blanco
    blanco Road Train Member
    1,221
    296
    Nov 20, 2009
    Gwinnett County, GA
    I think JohnP pretty muched covered everything.. I can't think of anything else..
