Cummins N14 Red Top Code: MID 130 SID 231 FMI 7
Discussion in 'Volvo Forum' started by ReneJRR, Oct 10, 2019.
  1. ReneJRR
    ReneJRR Bobtail Member
    38
    7
    Jan 14, 2017
    2000 Volvo VNL 770
    N14 Red Top
    Eaton Fuller Transmission
    My volvo is a semi automatic because it has a clutch wich you only use for engaging gear 1 or 2 depends on what gear you want to start after he shift automatically...
    I’m having a issue where the truck gets stuck in a gear while running at any speed in any gear and it doesn’t shift down and it doesn’t respond to the pedal when you trying to accelerate and it doesn’t go to neutral and it will turn off because clutch doesn’t work either then i turn it off remove the positive from the battery after 10 put back on and works perfect after a while driving it it starts doing the same thing..
    This is the code im getting in the cluster
    Transmission
    SID = 231
    Mech Syst No Respons
    Active
    Count 1
    MID 130
    SID 231
    FMI 7
    Any help will be very appreciated!!
  3. boneebone
    boneebone Road Train Member
    2,297
    2,371
    Mar 13, 2009
    Problem could be X Y shifter needs to be looked at or replaced.
    ReneJRR Thanks this.
  4. ReneJRR
    38
    7
    Jan 14, 2017
    whats the X Y shifter?
  5. QUALITYTRUCK
    1,816
    1,782
    Jun 14, 2009
    romulus,mi
    Buddy. You better get some professional help. It will save you time=$$
    Bean Jr. Thanks this.
  6. ReneJRR
    38
    7
    Jan 14, 2017
    Thanks for your advice, it help me a lot! Maybe we should close all 149 pages of questions we got in this forum with “Get professional help”
  7. QUALITYTRUCK
    1,816
    1,782
    Jun 14, 2009
    romulus,mi
    There are some things that you can attempt to diagnose and repair yourself. An Eaton Autoshift transmission is not one of them, especially if you do not know what an xy shifter is. I admit that I could have worded my response in a much better way. For that I apologize. My intent remains. Get some help at a shop that has Service ranger software and knowledge of that system.
    Newto Trucking, ReneJRR and Bean Jr. Thank this.
  8. boneebone
    2,297
    2,371
    Mar 13, 2009
    What city are you located in?
  9. ReneJRR
    38
    7
    Jan 14, 2017
    Miami, FL
