Cummins n14
Discussion in 'Ask An Owner Operator' started by Fld1201994, Jul 22, 2021.
  1. Fld1201994
    Fld1201994 Bobtail Member
    29
    15
    Jan 25, 2020
    Hello fellas, I have a Cummins n14 that when I go to start it up it’s start but then after 2 to 3 seconds it dies , then I go ahead and try again to started up and it cranks for a bit then starts liked if I had sprayed some started fluid and stay on with no problem …. Now a few days ago it started acting like if it was running out of fuel with a lot of white smoke and it wouldn’t rev up but that only lasted like 40 seconds to a minutes at the most then ran fine afterwards , any thoughts? Thanks for your time fellas
  3. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    restriction in the fuel somewhere?
    Dino soar and Fld1201994 Thank this.
  4. sbaumann14
    sbaumann14 Road Train Member
    1,236
    1,431
    Sep 1, 2010
    Rhinelander, WI
    Do u have the Davco filter? Sounds like ur loosing prime. There’s a check ball in the bottom of filter housing that keeps the fuel from running back into ur tank when u sit. They wear out
    Fld1201994 Thanks this.
  5. Fld1201994
    29
    15
    Jan 25, 2020
    The filter housing that I have its connected straight to fuel pump with the fs1000 fuel filter , I replaced the check valve that goes on the ecm cooling plate liked 2 years ago , I’ll go ahead and tried replacing it again.
  6. bad-luck
    bad-luck Road Train Member
    3,431
    6,319
    Nov 16, 2013
    Baltimore, Maryland
    Change the fuel filter first. Go from there.
  7. Dino soar
    Dino soar Road Train Member
    4,815
    27,071
    Dec 8, 2017
    I'm not saying this is your problem but on older trucks sometimes the fuel lines themselves can internally collapse.
    Sometimes that can happen in such a way that as the fuel really starts to get flowing it shuts itself off.
    I would try running fuel directly out of a bucket to the pump to isolate whether you have a problem before the pump or after the pump.
    That's how I do it on the big cam anyway. I assume you can do the same thing on the electronic engine.
    spindrift, jamespmack and Fld1201994 Thank this.
  8. Fld1201994
    29
    15
    Jan 25, 2020
    I just replaced the filter and it’s the same
  9. Fld1201994
    29
    15
    Jan 25, 2020
    That is what I was thinking, because I might be wrong but I believed that the fuel lines on the truck there original
    jamespmack Thanks this.
  10. abyliks
    abyliks Road Train Member
    4,110
    9,671
    May 2, 2010
    ludlow MA
    Cam sensor could be on its way out to, I carry a spare under my bunk
    jsnell, ChevyCam and Fld1201994 Thank this.
  11. bad-luck
    3,431
    6,319
    Nov 16, 2013
    Baltimore, Maryland
    Ok, it sounds like you may have a cracked fuel line, and are sucking air.
