Cummins NT855 serial no. help
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by cosullivan26, Sep 23, 2024.
  1. cosullivan26
    cosullivan26 Bobtail Member
    11
    6
    Aug 25, 2024
    Hello folks!
    Been trying to find my serial number on this engine. No dataplate (of course) and it looks like the serial was mis-stamped on the block. The data plate on the fuel pump shows a 113cpl but that shows the engine is a 270 when the truck data plate says it’s a 290?? Is there any other location where I can find the serial number? IMG_3421.jpeg
  3. cosullivan26
    11
    6
    Aug 25, 2024
  4. cosullivan26
    11
    6
    Aug 25, 2024
  5. AModelCat
    164,601
    Even with a S/N it might not mean much. Who knows what's inside that engine now or if its even original to the truck. A previous owner could have built a Frankenstein engine too.
  6. SmallPackage
    5,777
    18,547
    Dec 20, 2019
    Marion Texas
    A 270 is considered a 290 just different fuel code. Just like the 250 also had different codes and also rated at 230 and 240 depending on chassis it went in to.
  7. beastr123
    beastr123 Road Train Member
    2,951
    24,201
    Jan 2, 2014
    Moose Jaw SK CAN
    The 270 I used for switching and training in the late 70's pulled better than our 290s because the turbo/fuelpump combo was setup for a higher torque at a lower rpm (the torque came on at 1500 for the 270 instead of 1700 for the 290).
    I was told the 270 had a bigger air side turbo wheel driven by a smaller (faster) exhaust wheel moving more air at a lower rpm and the pump was calibrated to feed more fuel earlier in the curve while still only pumping enough fuel for 270 /290 hp at 2100.
    Our mechanic at the time was a wizard at tuning PT systems and loved the combo and even used a somewhat similar system on the 350 he built for me for heavy haul. Having a long torque curve in a high horse engine (for the day) was excellent when paired with a 5x4 trans and 5.29rears in 55k housings when pulling up to 250k loads on up to 50 wheel combos (2-8-16-16-8).
  8. cosullivan26
    11
    6
    Aug 25, 2024
    Well that’s good to know. Kind of a downer when I found out I have the “baby” version of the 855. Luckily this truck is officially retired under my ownership. Slapped antique plates on it and just going to take it to and from shows and just cruise her around. Any way to make the turbo louder? Love to hear that scream!
  9. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    We made a lot of lower power NTC's into 400 + HP. You have no idea what you have anymore. We scribed data for what we had done.
    The factory 270 surprised me. RTLO 7 speed overdrive with 5.29 rears . Gauges would read 80 MPH at 2500 RPM but not recommended, I was just along for the ride.
    Those 270 BCIII, were torque monsters in their day. They really surprised me.
    Ok but just what I remember. 250's were none turbo. Then they jumped to a 290 with a turbo.
  10. SmallPackage
    5,777
    18,547
    Dec 20, 2019
    Marion Texas
    Yes sir. You are correct. Was just using 250 as another example since it was the only other engine Cummins custom rated lower then advertised so to speak.
  11. BoxCarKidd
    4,548
    6,641
    Aug 26, 2014
    My 250 non turbo small cam has no cooling nozzles. You cannot build much power on that. The 270 Big Cams I thank had HT3B's and preformed very well with what was out there in the late 80's.
    ElmerFudpucker and SmallPackage Thank this.
