Cummins X15 need help
Discussion in 'Ask An Owner Operator' started by Rex012, Dec 28, 2022.
  1. Rex012
    Rex012 Light Load Member
    256
    76
    Apr 12, 2014
    Hi Everyone,
    I have a 2020 kw t680 with 184k miles with the following codes. truck will derate.
    1142-Injector solenoid driver cylinder 3
    1656- Engine misfire cylinder 3
    5897-engine misfire cylinder 3
    it is currently in the shop for 6 days and they can't diagnose the issue just yet. Any idea what I can do? thinking of taking it to another shop.
  3. Midwest Trucker
    5,914
    21,388
    Aug 31, 2018
    Take it to a factory Cummins shop and get warranty work done. They’ll do it right.
    Opendeckin, Siinman, ducnut and 2 others Thank this.
  4. birdmanfromsc
    birdmanfromsc Bobtail Member
    25
    19
    Oct 6, 2013
    upstate, sc
    Take it to Kenworth...they'll fix it
  5. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,382
    Jul 16, 2012
    Bentonville Arkansas
    First thing first! make a Cummins QuickServe Online account and add your ESN in then go to fault code search and put all 3 codes in. It will tell you what code to start with. More then likely code 1142 is the one causing all the other ones. Could be a bad injector to a bad return line to a bad wiring harness.
    dosgatos, Siinman, Concorde and 3 others Thank this.
  6. Rex012
    256
    76
    Apr 12, 2014
    We checked the injector and harness and they’re good. So it’s giving us a head scratching moment lol.
  7. TruckerPete1990
    8,623
    5,382
    Jul 16, 2012
    If its a dealer they should be following the 4 steps in the repair tree.
    Siinman Thanks this.
  8. Rex012
    256
    76
    Apr 12, 2014
    Well we have abd everything checks out so that’s why I’m asking :(
  9. TruckerPete1990
    8,623
    5,382
    Jul 16, 2012
    Are you running any after market sensors?
  10. Ridgeline
    22,719
    123,163
    What shop are you taking it to?
    A third party shop or a dealer or a cummins owned shop?
    Siinman and Midwest Trucker Thank this.
  11. Rex012
    256
    76
    Apr 12, 2014
    nope they are all original.
