Curiosity question about weights....
Discussion in 'Experienced Truckers' Advice' started by Commuter69, Jan 11, 2023.
  1. Commuter69
    Commuter69 Road Train Member
    1,142
    635
    Jul 2, 2014
    I understand the allowable weight distribution on a typical 5 axle configuration for a 75' combination....
    Not that I would ever NEED to know this, but is there a broad stroke reference (or video) that explains:
    What additional/drop axles do?
    Spread axles do?
  3. Long FLD
    Long FLD Road Train Member
    12,835
    53,707
    Mar 4, 2015
    If you’re wanting a general broad stroke then that would be the Federal bridge chart.
    gentleroger Thanks this.
  4. Crude Truckin'
    Crude Truckin' Alien Spacecraft
    2,455
    6,860
    Oct 22, 2016
    North Dakota, Eh?
  5. tscottme
    tscottme Road Train Member
    Each additional axle can carry X amount of extra weight (17,000 pounds, for example), but the whole vehicle/combination may or may not be allowed to go over 80,000 pounds gross weight limit. MI, for example allows trucks/trailers with enough axles to pull over 100,000 pounds on the roads, and maybe only during certain winter months, I don't remember.
    A spread axle usually can carry more than that X amount of weight.
    For example, each axle of a tandem set can carry 17,000 each for a tandem total of 34,000 pounds. A spread axle, say a minimum distance of 10 feet from the other axle can carry 20,000 pounds. The spread feature allows you to carry extra weight because the higher weight is not concentrated in just the distance between the front and rear axle of a tandem set of axles. The spread of the two axles doesn't harm the road as much as the tandem axle.
  6. skallagrime
    skallagrime Road Train Member
    3,855
    9,927
    Apr 10, 2012
    Indiana
    But now the why people like them (spread) so much in flatbed.
    Try weighing 30500 with truck and trailer, carry a 49k coil. Misplace it by a foot and youll never axle out right even if by some miracle your tandems still slide
    tscottme Thanks this.
  7. ducnut
    ducnut Road Train Member
    2,683
    8,131
    Dec 31, 2010
    SPI
    That’s not completely accurate. Its purpose isn’t to allow you to carry more on the spread. Its purpose is to better support concentrated loads, like a single coil. Because they’re further than 96” apart, they’re viewed as two separate axles (20K pounds each), which is what allows for the combined 40K pounds rating. Because the front axle is positioned further forward, that causes the spread axles to naturally carry more weight, over them. If one starts loading spread axles with the idea they can carry more over them, one WILL get bit and end up too heavy on them. DAMHIK. :D
  8. ducnut
    2,683
    8,131
    Dec 31, 2010
    SPI
    That’s not true at all. A single coil off a foot is the same as the center of a full trailer load being off a foot, because you’re still dealing with a 1’ foot off-centered load. You’d still be able to move the tandems for a correction. The bigger issue is that single coil is going to make the trailer hammock so bad I would refuse to load it. If flipping a coil is the desired outcome, that’d be the way to do it.
  9. tscottme
    Yeah, I'm obviously not a flatbedder. Thanks for the explanation.
    ducnut Thanks this.
  10. ducnut
    2,683
    8,131
    Dec 31, 2010
    SPI
    No worries.
    Because the axles are spread configuration and viewed as separate axles, you’ll often see a spread get “split” at DOT scales. They’re hoping to catch a faulty/incorrectly adjusted ride-height valve and being heavy on one of the axles. I used to regularly run over 79K pounds. Getting split was a regular deal. Any chance at nailing someone. :rolleyes:
  11. Ridgeline
    22,717
    123,131
    Go here and read ... it is complicated but if you get it, you will understand a great mystery and be a weight guru.
    Hendrickson - Bridge Laws
    ducnut and tscottme Thank this.
