D12d water filter
Discussion in 'Volvo Forum' started by Helowrenchturn2, Jul 8, 2013.
  1. Helowrenchturn2
    Helowrenchturn2 Medium Load Member
    484
    140
    Apr 23, 2013
    Can I replace the water filter on this thing without losing all my coolant??
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    drain coolant first and you loose some coolant anyway. yep, you can use bucket under filter area when you do replacement and reuse collecter coolant, but I see no reason, really
  4. dorlia2
    dorlia2 Light Load Member
    149
    28
    Apr 20, 2012
    DOWNERS GROVE
    There is a shut-off valve behind the coolant filter housing
    Helowrenchturn2 Thanks this.
  5. Helowrenchturn2
    484
    140
    Apr 23, 2013
    Yeah, I found that. Unfortunately it's seized up :(
  6. dorlia2
    149
    28
    Apr 20, 2012
    DOWNERS GROVE
    Had the same problem, just don't force it, work it back and forth
