D13 Antifreeze engine block drain?
Discussion in 'Volvo Forum' started by MIg25, Jun 26, 2023.
  1. MIg25
    MIg25 Light Load Member
    73
    20
    Apr 10, 2020
    Fort Lauderdale - Florida
    Hello,
    Is there an antifreeze engine block drain? I looked at the manual it mentions it but does not show the location.
    Also is there an air purge valve for the cooling system?
    Thank you.
    This is a VNM 2014 with a D13 Engine.
  3. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    there is no air purge valve, they have two de aeration hoses connected from the head, and one from the radiator there is a few ways do drain coolant from the block on passager side at the oil cooler there is a plug should be 24mm wrench or there is a coolant pipe that goes behind the engine you can also remove this and it will drain 80% of the block.
    NWAF and MIg25 Thank this.
  4. MIg25
    73
    20
    Apr 10, 2020
