D13 Engine hours
Discussion in 'Volvo Forum' started by biofumes, Mar 8, 2019.
  1. biofumes
    biofumes Light Load Member
    202
    96
    Feb 13, 2009
    California
    I'm still researching a 2013 d13 vhd, the engine hours read 15,000 hours, mileage is 210K, so it seems its mostly been running the pto idling.
    So how many hours are to many hours? I'm used to using mileage. So far I'm seeing these engine will make 1 million miles, with the normal wear and tear parts replacements.
    Thanks
  3. fss99701
    fss99701 Medium Load Member
    327
    663
    Feb 14, 2019
    none of your business
    If you considered 60 mph for each hour on the engine that would be 900000 miles.
    And I believe idling the engine is worse than driving it I would say that truck has too many hours the engine is done.
    I would definitely look for another truck if I was you.
    Good luck.
  4. daf105paccar
    6,564
    7,294
    Apr 15, 2012
    All depends on the $$$$$.
    Is it cheap?
  5. biofumes
    202
    96
    Feb 13, 2009
    California
    Its average priced, it just has the specs we need, tag axles, gear ratios etc.
    ddif Thanks this.
  6. fss99701
    327
    663
    Feb 14, 2019
    We'll just add in another $20,000 on top of the price they want, so you can get the engine overhaul, and if it still seems doable at that price go for it.
    KB3MMX Thanks this.
  7. biofumes
    202
    96
    Feb 13, 2009
    California
    I was lucky enough to find a tech from a dealer, he mentioned his sheet shows, every 750 hours equals 30K miles. So I am looking at a 2013 D13 with 600K miles of actual use, and not the 200K miles I originally thought.
    Thought I'd pass along the info.
    NWAF, NCTru919, KB3MMX and 2 others Thank this.
  8. Cattleman84
    Cattleman84 Road Train Member
    10,002
    71,354
    Nov 1, 2017
    The Sticks, Idaho
    I would say that if 80% of the engine hours multiplied by 60 mph doesnt come close to the actual miles on the engine then it is to many hours.
    ddif and fss99701 Thank this.
  9. Ridgeline
    22,708
    122,433
    Do not use 60 mph, use 48 mph.
    Also do an ecm dump and see what hours are what, there are two types in the ecm
    NCTru919 and KB3MMX Thank this.
  10. Amram
    Amram Medium Load Member
    448
    235
    Feb 4, 2017
    My engine has 19608.5hrs with 705287 miles on it. 6753 of those houts is idling. Just to give you a picture. My fuel economy took a dump last winter and now Im lucky to get 6 mpg. I hate this little green engine. Its junk.
    Newto Trucking Thanks this.
  11. Newto Trucking
    Newto Trucking Medium Load Member
    359
    226
    Dec 26, 2013
    NE Illinois
    Do you idle overnight or you have a bank heater or apu??
