dash board blitz
Discussion in 'Freightliner Forum' started by davidg387, Jul 16, 2015.
  1. davidg387
    davidg387 Bobtail Member
    4
    I have a 2010 cascadia freightliner. The other day I was in a heavy down pour of rain and my dash blinked out a couple of times but when it came back on it is blinking, lights on, can't turn wipers on etc. nothing is turned on and can't get my a c on. Please help is it my ecu?
  3. Oldman49
    Oldman49 Medium Load Member
    353
    300
    Jul 20, 2014
    Cascadia are famous for electrical issues. Our truck was working fine till stopped for fuel. Flashers wouldn't work,dome lites wouldn't shut off, dash lights dim and uncontrollable. We parked, shut the engine off. Waiting on hold with breakdown,,suddenly dome lites go off flashers start working ,everything normal. If you have a master battery shut off,,,turn it off for a few min let everything reboot..did it 3 times over a month then didn't quit again...dealer couldn't find anything...good luck
    Getsinyourblood Thanks this.
  4. purpleprime
    purpleprime Medium Load Member
    681
    720
    May 30, 2013
    spickard, mo
    Cascadia are also famous for lea king around the windshield and clearance lights letting water in behind the dash and into the electrical system so if you find your problem and fix it you also need to find your leak and fix it to keep it from happening again
    magoo68 Thanks this.
  5. wall_404
    wall_404 Bobtail Member
    37
    7
    Apr 22, 2015
    Ontario, Canada
    We have a 2005 Western Star tri axle dump truck that had the same problem. The wind shield or clearance lights leak in to the dash. We thought it was the ECU as well. We had the wiring harness replaced last week and every thing works great now, except for finding out where it leaks.
    Also similar problem with our 2005 Mack tri axle dump truck. It turned out the fuses under the hood were getting corroded from water splashing up and getting in. Cleaned up the corrosion, reinstalled the fuses and made a make shift cover (additional) out of an old inner tube, no problems in the last 2 years.
  6. average joe
    average joe Medium Load Member
    432
    274
    Jan 11, 2009
    Freightliner has such good quality control
  7. taxihacker66
    taxihacker66 Road Train Member
    1,354
    1,287
    Feb 26, 2012
    Concrete jungle.
    Cee senor :pottytrain4:
  8. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    its not ECU its a Sam CAB. Check right bottom corner of windshield. you must have leak there. )))) The water probably went into sam cab and its burned already. Only freightliner dealer can help you . get ready to pay $1500-1700...
  9. mhyn
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    I gues you wanted to say Si Senor . )))) But he is right about freightliner quality.
  10. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    When the water leak happened on my old 2009 I had same issues and the horn stuck on... Had the replace a couple computers and fuse box ... Freightliners fix was a windshield gasket with a extra hump on it ... We got windshield guy to reseal the fix which still leaked ... Be careful if you sleep in truck some have burnt down due to wiring fire
  11. mhyn
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    I have replaced the seal. its still leaking. the electric horn( and washer motor) was on until horn got burned. Washer motor's circuit is logic controlled and its burned too. no way to stop the leak and now I am thinking to make some rain gather inside of the cab up to fuse box..)))) just wondering who was the designer ..)))
