1. Winners
    Winners Bobtail Member
    Aug 12, 2018
    Thanks Received:
    hey car haulers any recommendations on a good dash cam I’m looking to buy one.
  2. WX4JCW
    WX4JCW Light Load Member
    Nov 20, 2009
    161
    Thanks Received:
    67
    Orlando, FL
    i have the garmin one, its not bad
    misterG Thanks this.
  3. jammer910Z
    jammer910Z Road Train Member
    May 28, 2015
    2,446
    Thanks Received:
    6,522
    I've run a Garmin for about 6 years.
    It does a really good job.
    I replaced the 4gb card with a 34gb so it wouldn't wear itself out so quickly.
    After all of this time, the lens has developed a sun spot on the screen.
    I'll probably replace it with another.
    $120÷6 years is only $20/yr for peace of mind.. and it's still kickin.
    misterG and Swiss Mountain Dog Thank this.
  4. IluvCATS
    IluvCATS Road Train Member
    Dec 1, 2014
    4,091
    Thanks Received:
    8,976
    Seattle, WA
    I looked at the Garmin dash cam too. Does it help that I have a Garmin gps with Bluetooth enabled? As in do they communicate? Or is that unimportant. Because the Cobra brand also looks equally nice (and small).
  5. jammer910Z
    May 28, 2015
    2,446
    Thanks Received:
    6,522
    Not sure @IluvCATS
    I usually don't connect everything anyway.
    Just scrolled through the settings on this older one and see no BT connectivity.
    Newer versions MAY.
    Also.. since you love cats, have you seen TALKING KITTY KAT on You Tube?
    I had one just like that cat.
    Mean as the devil.
  6. Balakov100
    Balakov100 Road Train Member
    May 10, 2012
    3,938
    Thanks Received:
    2,641
    Temple, TX
    You mean 32??
    Wear out? Huh
  7. Cottonmouth85
    Cottonmouth85 Bad Influence
    May 3, 2012
    2,637
    Thanks Received:
    8,701
    Floresville, Tx
    Got a Garmin 65 and 64g card. Have yet to install it.
  8. jammer910Z
    May 28, 2015
    2,446
    Thanks Received:
    6,522
    My apologies for not being a tech nerd.
    I drive a truck.. drink beer.. and like women.
    I don't spend my time researching the newest trends in technology or worrying whether or not I stated a memory card was a 32 or a 34gb.
    It really doesn't change my life any.
    The 4gb card.. after being used for about 2 years wasn't able to be recorded over any longer and the unit shut down.
    I talked with customer service and they told me that was likely the problem.
    I replaced it with the larger gig card and it fixed the problem.
    SATISFIED??
  9. Snailexpress
    Apr 28, 2014
    2,675
    Thanks Received:
    6,069
    Rocky
    Just in installation process with this one
    4 Channel 3G AHD WiFi GPS Real-time Vehicle Surveillance Cameras with Dual SD Cards Backup
    Features:
    – HIS Solution,H.264 Compression, Dual Stream,4CH Video and 4CH Audio input;720P AHD Camera & Normal Analog Camera input compatibility;
    – High quality real time recording, 720P/CIF/HD1/D1 adjustable;
    – Support Built-in 3G network, WCDMA,CDMA2000
    – Support WIFI 801.2b/g/n, 801.2a/c wireless transfer
    – Professional Car Power Design,10-36V wide voltage,Provide reverse voltage/overload/short circuit protection, to meet kinds of car application;
    – Support 12VDC/2.5Amp output voltage,power supply for Camera/Screen etc;
    – Dual SD Card Support, each max 128GB,,protect DVR from shock & Dust damage;
    – Watchdog abnormal restart function,protect SD Card and Record;
    – Exclusive File System protect data completeness,prevent SD Card fragment;
    – ACC Delay off,can set 24 hours;
    – Auto Record/Manual Record/Alarm Record etc working mode to meet different requirements;
    – Show Car status/Plate/Driving Route/Low Speed/Over Speed information for convenient management;
    – Support GPS/BD G-sensor Optional;
    – 3CH Alarm input(Door Open,Light,Turn direction,brake,reverse etc),can linkage kinds of alarm; 1CH Alarm Output;
    – Support picture snap when alarm;
    – Easily Smart GUI Interface, saving time in device setting;
    – Stability Aviation plug, easily connecting and high shock proof;
  10. Oldironfan
    Oldironfan Road Train Member
    May 22, 2017
    5,777
    Thanks Received:
    5,543
    I don't understand these things?
