Day cab hammock.
Discussion in 'Experienced Truckers' Advice' started by Dominick253, May 23, 2017.
  1. Dominick253
    Dominick253 Heavy Load Member
    746
    634
    Nov 19, 2015
    So I seen a hammock designed for day cab trucks online and took a chance and bought one. A little pricey at $55 but it makes those 4+hour delays so much more bearable. I highly recommend it to any local driver who has long waits for loading and unloading. Edit says 250lbs on their website. Home
    pattyj, GoBlue487, rank and 3 others Thank this.
  3. Chinatown
    Chinatown Road Train Member
    77,557
    183,055
    Aug 28, 2011
    Henderson, NV & Orient
    I bought a cheap hammock that rolls up into a ball about the size of a softball for storage.
    Installed an eye-bolt in upper right corner just above windshield and another eye-bolt just above the back of the drivers seat. I would hang the hammock from the eye-bolts, open the windows a little to get a breeze and then sleep like a baby.
  4. KillingTime
    KillingTime Road Train Member
    3,865
    61,879
    Mar 26, 2016
    Rockland, Maine
    I need to ask what's the weight rating.... GVWR... on that hammock? I go 190. Some of us do not.
    I ask only because I had this mental of a 350lb guy trying it and ultimately ending up stuck between the seats. For God knows how long. Lol.
    rbrtwbstr, pattyj, Grubby and 6 others Thank this.
  5. Dominick253
    746
    634
    Nov 19, 2015
    It
    said they tested it at 400+ pounds. I'm 170 and it's perfectly fine for me.
    KillingTime Thanks this.
  6. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,143
    Mar 5, 2016
    White County, Arkansas
    As a flatbedder, check under the deck in the middle where there might be a hammock in use, usually check also that the tractor is locked, chocked and engine off so that no one can take off with it and you under that deck. (And they have...)
    In my time we used a 5 foot board yea wide across the seats and out the pax door a little bit. That served well enough. Or stuffed yourself into a corner like a cat which you young ones can do without too much trouble. Not so much when you are along in years.
    Dominick253 Thanks this.
  7. Chinatown
    77,557
    183,055
    Aug 28, 2011
    The cheap one I used with the eye-bolts; first time I used it the eye-bolts spread open and dumped me. Had to install more heavy duty ones. I was 175 lbs at the time.
    The guy I was training slept in it laying on his stomach. I asked how in the world can you sleep in a net hammock on your stomach? He just said it is more comfortable that way.
  8. x1Heavy
    34,016
    42,143
    Mar 5, 2016
    That might hurt him in the later years as his body fights to eliminate fluids moving certain ways against nature at night. We sleep in whatever position we think best, but to sleep in a hammock stomach down is pretty dangerous over time. Not to mention the spine and other issues.
  9. Mr Ed
    Mr Ed Road Train Member
    1,380
    1,630
    Apr 6, 2009
    Retired in Taunton Ma
    I ask only because I had this mental of a 350lb guy trying it and ultimately ending up stuck between the seats. For God knows how long. Lol.[/QUOTE]
    Or firefighters having to pull a gear shift out of an orrifice
    starmac, Grubby, mindes and 6 others Thank this.
  10. Ubu
    Ubu Road Train Member
    1,252
    1,178
    Aug 25, 2012
    Rumored to be somewhere
    I'm visualizing the sides of the cab being bent in o_O
    starmac, magoo68, ncmickey and 8 others Thank this.
  11. Ougigoug
    Ougigoug Heavy Load Member
    971
    824
    Dec 4, 2012
    Planet earth
    If you want you want to be comfortable sleeping in a hammock you have to sleep sideways, that way you will be flat like a regular bed.
    In Yucatan Mexico there is still plenty of people's sleeping in hammocks everyday.
    G13Tomcat and Dominick253 Thank this.
