DD 15 Using Coolant. Can't Dind Leak.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by LandslideRich, Jul 27, 2024.
  1. LandslideRich
    LandslideRich Light Load Member
    292
    268
    Jan 13, 2017
    Charlotte, NC
    I have a Detroit DD15 that is going through roughly a gallon of coolant every 1000 miles. I checked the EGR and that's not the problem. I did notice some yellowish discoloration around 2 of my injectors, but no dripping fuel leak. Any suggestions on what may be my problem?
  3. Antinomian
    Antinomian Road Train Member
    2,173
    3,444
    Feb 17, 2013
    Pressure in the radiator?
    LandslideRich Thanks this.
  4. LandslideRich
    292
    268
    Jan 13, 2017
    Charlotte, NC
    Some until I let it cool down
  5. Antinomian
    2,173
    3,444
    Feb 17, 2013
    EGR leak is the most common cause of disappearing coolant and the first symptom is pressure in the radiator. After it has been run hot, then allowed to cool down completely, run the engine for about one or two minutes. Check the crossover pipe for coolant then. You have to catch an EGR leak at the right time to see coolant in the crossover.
    Take an oil sample and send it for analysis. Check for coolant traces in the oil. I assume you have checked to make sure the oil is not visibly contaminated and that there is no volume increase.
    Can be a bad head gasket but that usually causes a leak to the outside.
    Can leak into the transmission. You would see contaminated oil and a volume increase.
    Can leak through a bad compressor. That would be obvious in the oil.
    Can be a cracked liner.
    A gallon every thousand miles is most likely a bad EGR cooler or a cracked liner. That's a lot of coolant and it has to be going somewhere. If it's not in the crankcase or the transmission then it has to be going through the cylinders.
  6. LandslideRich
    292
    268
    Jan 13, 2017
    Charlotte, NC
    How would I go about inspecting the liners? Bore scope through injector port?
  7. Antinomian
    2,173
    3,444
    Feb 17, 2013
    Do the oil analysis first. And did you check the EGR the way I said?
    You might spot a crack in a liner with a bore scope. I would start by pulling the oil pan off and pressurizing the radiator. See if any drips happen.
  8. Diesel Dave
    9,653
    32,670
    Jan 20, 2010
    Hesperia, Ca.
    Had a similar issue and it was transmission cooler leaking coolant into the transmission. Easy to check, remove the fill plug and if the fluid pours out, you have you answer.
    cascadia4life and LandslideRich Thank this.
  9. cascadia4life
    cascadia4life Light Load Member
    107
    99
    Apr 21, 2023
    Never thought about this one.
    I was researching online for a different issue and came across this. Very interesting. Thanks for sharing.
  10. Lockport
    Lockport Light Load Member
    201
    131
    Mar 26, 2011
    Lockport, MB, CAN
    It's likely going into your One-Box after side of the turbo. That's not good. It'll destroy your One-Box
