DD 60s, yellow check engine.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by FC2007, Aug 23, 2020.
  1. FC2007
    FC2007 Bobtail Member
    6
    I drive, I press the accelerator pedal, the yellow check engine appears. released gas pedal, yellow check engine disappears. What could be the problem?
    Thank you.
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,541
    6,619
    Aug 26, 2014
    Top right search checking flash codes and similar things.
    FC2007 and AModelCat Thank this.
  4. thejudges69
    thejudges69 Light Load Member
    246
    316
    Aug 22, 2015
    Sounds like your TPS is starting to go bad. Is your throttle response ok? Does the CEL come on and stay on or is it flashing while holding the throttle pedal down?
    FC2007 Thanks this.
  5. Y-L
    Y-L Light Load Member
    93
    50
    Oct 1, 2013
    Mine use to do that and was getting a vpod code..
    FC2007 Thanks this.
  6. FC2007
    6
    Problem solved. I followed the advice of a friend and replaced six sensors. All wrong. Detroit service found the turbo sensor bad.
  7. FC2007
    6
