DD looping at idle
Discussion in 'Trucks [ Eighteen Wheelers ]' started by me myself and I, Nov 21, 2016.
  1. me myself and I
    me myself and I Heavy Load Member
    735
    312
    Oct 5, 2009
    vernon hills,Il
    Not mine. But I've seen several doing it and assumed there was something wrong. The other day I've parked next to what looked like a new Freightliner and it was doing same thing. I think it had AC on. Is it normal.
  3. 25(2)+2
    18,758
    45,946
    Sep 18, 2006
    the road less travelled
    Certain rpms sometimes induce a lope, usually give it a tap up and it quits the surge, it's right around 900 rpm on the one I drive.
  4. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    It's s fuel pressure regulator on drivers side behind all the fuel lines by filter .. I can't remember the cost to change it but I know it was more if it had a certain bracket in front of it .. truck had way more power and went up 3/4 mpg so it paid itself off quickly 2009 530 hp dd15 didn't have the bracket
    Socal Xpress Thanks this.
  5. Animosus
    Animosus Heavy Load Member
    731
    2,898
    Dec 7, 2015
    SE Wyoming
    Quantity control valve on the back of the high pressure fuel pump causes surging at idle. You can watch its current in diagnostic link and see it spiking, at idle it should be fairly consistent.
    P/N A0000900069
    They are terrible on 113 BBC cascadia and DD13s. Other than that fairly easy. I've never seen a pump installed without the bracket. And to remove the bracket you need to remove the air compressor coolant line and that bracket. Sometimes the inner fender, high pressure fuel lines and flange.
  6. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    I think fuel filter housing must be removed to reach the third bolt on dd15. Which value do you monitor in DiagnosticLink for this particular issue?
    Also that valve cost $800 when the entire reliabilt pump costs $1100. if its time to change it replace the whole pump.
  7. Animosus
    731
    2,898
    Dec 7, 2015
    SE Wyoming
    Fuel filter housing does not need to be removed. You do need to remove the high pressure fuel pump bracket to reach the back bolt. Monitor quantity control valve circuit current, should be a value in ma (miliamps).
    mhyn Thanks this.
  8. mhyn
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    I have seen some dd15 also do strange things at idle. One of them I saw was opening and closing egr valve at idle. The actuator was moving the rod back and forward. Have you seen this problem on trucks ? any idea what part could be faulty ?
  9. TA Transport
    TA Transport Bobtail Member
    18
  10. TA Transport
    18
    I replaced fuel quantity valve and it helped but still has a surging idle especially at startup. Seems to smooth out after running a bit but is not right?? Any suggestions
  11. mhyn
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    do you have 3 filter system or 2 filter system?
