DD15 "connected activity"
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by EZ Money, Jun 20, 2019.
  1. EZ Money
    EZ Money Road Train Member
    Hey guys! Wondering if anyone could help or if there was a way to remove connected activity from the trucks ECM?..I screwed up and was trying to connect without the backdoor password...Now there are about 50 entries on the ECM....Any trick to clearing these or am I screwed?
  3. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    is it your truck ? cpc has password ?
  4. uncleal13
    uncleal13 Road Train Member
    3,797
    6,297
    Apr 9, 2009
    Humboldt, Sk
    Connecting isn't really the problem. It's if you actually change the parameters or reprogram the engine. Then Detroit will freak out next time it's plugged into their system if it's still under warranty.
    EZ Money Thanks this.
  5. mhyn
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    it's ok to change parameters when truck is under warranty. You can't change something that will damage engine if you use standard or pro versions. The DL must be legal. When you use legal software they see who and when parameter changes were done. If DL is a cracked it will let 000000 in tool ID place. This will freak out Detroit. I have heard there is one more version of DL. The Engineering version. No independent user or shop has legal engineering version of DL. With this version you can play with many sensitive settings that can effect emission,..
    Intothesunset and EZ Money Thank this.
  6. uncleal13
    3,797
    6,297
    Apr 9, 2009
    Humboldt, Sk
    True, I have a legal Standard version. I was thinking in terms of using unlicensed versions that have deeper access.
    Intothesunset and mhyn Thank this.
  7. EZ Money
    Yes I have the Version 8.09 Professional ...And was told using the keygen and backdoor password would not leave a trace...WRONG. This was a copy of an active shop version but I only changed road speed and bumped up RPM to 1900......It does show a tool ID other than 000000
    How long does the trucks ECU hold this activity.....forever?
  8. mhyn
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    forever. why you worry about this?
  9. SoCalRed
    SoCalRed Medium Load Member
    437
    851
    Feb 7, 2017
    CA
    Company truck?
  10. Intothesunset
    Intothesunset Road Train Member
    2,289
    4,880
    Apr 15, 2019
    truck
    Interesting post. Looking forward to this.
  11. EZ Money
    Long term lease truck....They do a print out at each service. Not sure what all that print out shows so I set parameters back to what they had them at before service....(slug mode)...lol!
