DDEC 3 Piston Cooling Nozzles
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Peterbiltt, Oct 24, 2019.
  1. Peterbiltt
    Peterbiltt Light Load Member
    236
    88
    Aug 21, 2014
    Ontario Canada
    Is it possible to drill piston cooling nozzles in a DDEC 3 block? If yes, how to get it done? Has anyone done it ?
    jamespmack and Bean Jr. Thank this.
  3. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    From what I understand, at some point, the DDEC3's are already drilled, but I do not know what serial number they started drilling them.
    From what little I have gathered there is also some upgrades to the roods and pistons themselves in the DDEC4's that makes them stronger too, so am not sure how much a guy can really gain by just adding cooling nozzles. I really ned to do some more research on it, not sure why though.
  4. benjamin260_6
    benjamin260_6 Medium Load Member
    433
    484
    Aug 8, 2012
    Ontario, Canada
    They started with the DDEC 4s in May of 1998
    Bean Jr. Thanks this.
  5. jamespmack
    216,477
    Some place in 2000 you can get drilled rods too. Oil passage from crank to wrist pin. Money well spent. Depending on what piston you have.
  6. starmac
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
  7. Peterbiltt
    236
    88
    Aug 21, 2014
    Ontario Canada
    heres the deal, i was told slap in a bk kit into a gk you dont need to change anything.. i changed the connecting rods and not like my mechanic knows any better and doesnt tell me the gk pistons were cooled rod thru, i put the bk connecting rods with the overhaul kit and now obviously the pistons arent being cooled, so i need to do something about this.. is it possible? has anyone done it?
  8. starmac
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    I can't answer , but am learning, or at least trying to. What is bk and gk?
    From what I gather,you used ddec4 rods and pistons in a DDEC3 block, am I understanding right.
    If that is the case, I did not know the DDEC 3 cooled through the rods, I wondered how it was possible to not have piston squirters.
  9. jamespmack
    216,477
    Some GK had nozzles, but did not have drilled rods. The BK after sometime 2000 got updated drilled rods maybe others idk. I have rebuilt one GK to BK. Added the rods. Nothing fancy but changing parts.
