Dead battery I think
Discussion in 'Ask An Owner Operator' started by feldsforever, Dec 27, 2019.
  1. feldsforever
    feldsforever Road Train Member
    1,453
    1,440
    Nov 22, 2019
    Sitting in maine. I can't get the truck to start. I did put in. Anti gel then drove about 12 miles. I was hoping that would help it blend in better. I always add it when in new England when it sits for a day or two.
    And I switch the main power off.
    I came down this morning and the ol' girl dont want to start. The electronic gauge is reading 12.8 volts. Its normal 14.1 0r 2.
    I'm sitting in my car trying to charge it back up.
    My question. Should the main power be on or off. Its currently on. I'm thinking it won't charge if its off?
  3. 201
    201 Road Train Member
    12,753
    26,228
    Apr 16, 2014
    high plains colorado
    You mean, won't turn over or spins but won't start. If it won't turn over with 12.8 volts, which is normal, might be a bad ground to the frame. Try the ground jumper( black) from your car right to the frame, see what happens. If it only clicks, bang on the starter with a hammer.
  4. Hulld
    Hulld Road Train Member
    2,884
    6,568
    Oct 19, 2015
    Upstate NY
    If you have the jumper cables hooked directly to the battery posts it will charge either way and it doesn’t matter.
    rachi and blairandgretchen Thank this.
  5. feldsforever
    1,453
    1,440
    Nov 22, 2019
    Got it going. I had to walk away for a little bit I was getting fusterated.
    Came back hook the cable back to it. Volts where at 13.8 fired right up. Thank you for your help. I noticed the positive charger post on the truck was moldy corroted. Will mild sand paper hurt it?
    Its not my truck but I do try to take care of it.
  6. flood
    flood Road Train Member
    4,168
    4,047
    Dec 25, 2010
    Remember volts and AMPS are not the same thing.
    It's amps that start the truck. Most trucks need a Minimum 1,000 amps to crank.
    If you had to jump it 1st check and clean the batteries/cables. That may fix it. If not need to have the batteries "LOAD TESTED" 1-2 of them may be bad..
    As to the battery kill switch it just kills power to the truck. it can be on or off when charging as long as your cables are hooked to the batteries
    rachi Thanks this.
  7. feldsforever
    1,453
    1,440
    Nov 22, 2019
    Thank you this is good knowelage. I will talk with the truck owner about the load test. This is the first time that it happened. But temp was sub 30 degrees.
    I'm in New York now 31 degress and she fired right up after sitting all night.
    Cabinover101 and rachi Thank this.
  8. Michael 247
    Michael 247 Heavy Load Member
    894
    4,689
    Nov 20, 2017
    Dublin Va
    Sandpaper won't hurt it but a Wire Brush works better
    Cabinover101, flood and rachi Thank this.
  9. npok
    npok Light Load Member
    160
    172
    Sep 26, 2015
    Also check the terminals on the master switch to make sure they're tight & clean.
    Cabinover101 Thanks this.
  10. Cabinover101
    Cabinover101 Heavy Load Member
    726
    1,166
    Jul 28, 2019
    I always put additives in before fueling that helps mix them up well.
    . Hot water will disolve that mess on the batteries, but always good to clean them up and check for proper securement.
  11. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,143
    Mar 5, 2016
    White County, Arkansas
    If batteries are tired they are going to absolutely fail the load test.
    Buy new batteries Plural for the entire group. If one or two of three or four are sick, the others are not far behind.
    When you get into negative 30 degrees leave her running. A few gallons of fuel wont hurt her none.
    D.Tibbitt and flood Thank this.
