Dead battery issue
Discussion in 'Peterbilt Forum' started by Pat moore, Apr 29, 2019.
  1. Pat moore
    Pat moore Bobtail Member
    My 2000 379 has a dead battery issue
    My volt guage read around 14 while Truck is running
    But overnight truck goes dead
    I have shut everything off in truck
    And it still is dead in morning or hard to crank
    Batteries are 2 months old but are an off brand Palmetto battery
  3. speedyk
    speedyk Road Train Member
    1,837
    2,470
    Apr 8, 2015
    An ammeter hooked up when key is off will show if something is still drawing.
    King Michael and Rounded_nut Thank this.
  4. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    You either still have a draw or batts are junk . New dont matter, could have a bad cell in one.
    KB3MMX and JonJon78 Thank this.
  5. Z800xp
    Z800xp Bobtail Member
    20
    Feb 26, 2019
    Check the alternator. If the alternator is warm to the touch in the morning before you start it, then the alternator is drawing the current. Had this happen to me once.
    speedyk and Rounded_nut Thank this.
  6. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Does it have the built in frig. if so you will have to go inside it and turn it off every time you shut truck off?
    Intothesunset Thanks this.
  7. speedyk
    1,837
    2,470
    Apr 8, 2015
    So the relay the energises the field was stuck?
  8. KB3MMX
    KB3MMX Road Train Member
    3,075
    2,595
    Dec 29, 2014
    Orrstown, PA
  9. King Michael
    King Michael Light Load Member
    89
    72
    Nov 20, 2018
  10. King Michael
    89
    72
    Nov 20, 2018
    Check the lights that are underneath your bunk inside the side doors one of them may be staying on, I had that problem I did not realize it there was a switch on it I assume the light went out as soon as I close the side box door.
    That is enough of a drawer to kill a battery overnight, especially if they're still incandescent bulbs and not LED lights.
    Another issue could be batteries could be brand new did you clean your battery terminals with sandpaper a wire brush the part that actually connects to the battery your wires?
  11. King Michael
    89
    72
    Nov 20, 2018
    Do you have a power inverter?
    My batteries will drain within 2 days of I leave it on while I'm home.
    - check to see if you left a light on in the belly box under your bunk.
    If that doesn't solve the problem, take it to your car mechanic (unless you can do it yourself)
    turn everything off
    Open fuse box
    Check voltage draw on every single circuit
    Some will be powered no matter what
    Eventually, you'll find a circuit pulling power that shouldn't be
    Like the light under my sleeper, it has its own switch but was powered up (under bunk lights are easy to miss cause when you lift the bunk they automatically come on and when you open the belly box... Yep... They automatically come on) ... Thats how you find the problem
    On the cover for the fuse panel should be the "key" telling you what every fuse controls.
