dealing with hills and altitude changes
Discussion in 'Experienced Truckers' Advice' started by rpad139, May 19, 2014.
  1. rpad139
    rpad139 Heavy Load Member
    893
    566
    Jan 9, 2014
    Nevada
    I've noticed everytime I drive through pennsylvania I always get very light headed...I'm thinking maybe its because of all the hills you have to drive through and the constant "up and down." Is it because the blood that rushes to my head and back down? I don't know if its just me or does anyone else experience this as well? Its not just pennsylvania but any area where there is altitude changes or has lots of hills. The feeling reminds me of when you hang upside down and get back up real quick. Anyone else have the same experience?
  3. sherlock510
    sherlock510 Road Train Member
    1,066
    1,058
    Jul 26, 2011
    Intercontinental.
    Like riding a roller coaster out that way.
  4. TripleSix
    133,249
    I believe it's just you.
    Raiderfanatic, rank and STexan Thank this.
  5. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    The total change in altitude isn't that big in the east. Also the relatively quick up and down of it is good too. You are more likely to get altitude sickness if say you start the day at somewhere that is 1,000 feet above sea level then sleep that night at 6,000 ft or higher above sea level. That's how it used to work for me, anyway. Just something you get used to. The windows down to get that cold air flow might help you.
  6. walstib
    walstib Darkstar
    If you're explaining it without exaggeration, I'd see a doctor, that's not normal.
    tinytim Thanks this.
  7. buzzarddriver
    3,823
    11,528
    Feb 1, 2011
    Dallas, TX
    Sounds more like sinus or ear canal problems. The elevation change in the east is not near enough to cause blood pressure problems.
    Now if you start your day in western Kansas and stop for the night in Aspen, CO, then your light headedness could be altitude related.
  8. sexysenior
    sexysenior Bobtail Member
    27
    20
    Sep 4, 2013
    anniston, AL
    Try eating more protein, eggs, fish, peanut butter. Lay off the sugar, salt and caffeine unless you're really tired and never eat Turkey before driving. And I just heard a study that said people over 55 can cut their chances of getting a stroke by 40% by eating more fruits and vegetables. Hope that helps.
    Lepton1 Thanks this.
  9. Derailed
    Derailed Road Train Member
    2,384
    2,657
    Dec 10, 2008
    Upstate NY
    Is this something you have always experienced or just recently? Do you have a head cold or stuffed up from allergies? Like others said, if your healthy you shouldnt be experiencing this from any hills in PA, at least not in a big truck.
  10. rpad139
    893
    566
    Jan 9, 2014
    Nevada
    I'm thinking maybe I should just eat healthier, maybe ive been eating too much sugar or too much carbs that's causing that feeling
  11. Lepton1
    Lepton1 Road Train Member
    12,647
    25,589
    Nov 23, 2012
    Yukon, OK
    Definitely sounds like issues with blood sugar rather than anything to do with altitude.
    I have spent a fair amount of time years ago climbing and guiding on high mountains. As part of the training there were extensive courses in backcountry first aid. High altitude sickness usually manifests itself at around 10,000 feet, but there have been cases as low as 8,000 feet. You have to be AT the altitude for a period of time to experience it.
    Symptoms of high altitude sickness are: nausea, headache, dizziness, and shortness of breath. Severe cases can include high altitude pulmonary edema (HAPE) or high altitude cerebral edema (HACE), both of which can be fatal. HAPE or HACE is basically your body fluids leaking into your lungs or into your cranium. The ONLY cure is to get to lower elevation quickly. HACE can result in sudden blindness.
    High altitude issues for truckers is something to consider if you are running over some of the highest passes in the west or considering taking a 10 above 8000 feet. Be aware of the symptoms and GET DOWN if you feel anything coming on. HAPE starts with gurgling in the lungs and can debilitate you within hours. Even if I am feeling nausea or headache I will get down to a lower elevation, before it progresses into something more serious. I would declare a personal emergency to move if I'm out of hours.
    High altitude can be lethal, but it is rare and requires staying at altitude for hours.
