DEF cap doesn't seem to vent.
Discussion in 'Peterbilt Forum' started by Edjahman, Jul 10, 2019.
  1. Edjahman
    Edjahman Medium Load Member
    648
    444
    Apr 2, 2013
    Hello.
    I have a brand new 579 and there is a whooshing sound when I remove the DEF cap. Is this cap supposed to vent?
    I assume it does.
    Has anyone had this problem?
    I assume that the cap is bad.
    Thank you!
  3. pushbroom
    pushbroom Road Train Member
    1,788
    7,394
    Sep 1, 2012
    Cap does not vent. Vent is part of the level sensor in the top, should be a 3/8 rubber hose coming off the top down the backside of the tank. You will have to pop the rubber boot on top of the tank off to see
    Edjahman, spsauerland and Goodysnap Thank this.
  4. Goodysnap
    Goodysnap Road Train Member
    3,771
    9,195
    Jul 12, 2017
    The tank will usually get sucked in under vacuum when the vent is plugged. Follow the hose from the level sender around the back side of the tank. It is likely pinched or blocked somewhere. There is a black plastic filter in line with the hose. As @pushbroom says the cap is not vented.
    Edjahman and spsauerland Thank this.
  5. Edjahman
    648
    444
    Apr 2, 2013
    Thank you! They didn't remove the plug from the factory!
    Take care
    spsauerland, uncleal13 and Goodysnap Thank this.
  6. Goodysnap
    3,771
    9,195
    Jul 12, 2017
    I have seen this before. Plastic cap was still in the hose. Da........
    Glad it was easy.
