DEF quality
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Sfrappier, Jul 12, 2018.
  1. Sfrappier
    Sfrappier Bobtail Member
    10
    Feb 18, 2017
    Is it possible DEF can sit too long in tank and go bad? I bought a 2013 Cascadia and when it was picked up the tank was full, have no idea how long it sat at dealer or with original owner. Have had NOx sensor issues since day one, replaced entire one box, all sensors got about 800miles out of it and same NOx codes came up. Found exhaust leak by intake fixed, parked regen and another code. Could this be as simple as bad DEF? Thank you in advance. Latest code btw is 4634-18
  3. FlyingA
    FlyingA Bobtail Member
    46
    23
    Jun 3, 2018
    Sacramento, Ca
    Yes. It could also have been a bad batch. Is the other code for NOX or something related? Exhaust leaks will also set codes for faulty NOX.
  4. AModelCat
    164,515
    Yep. DEF needs to be a specific mix of urea and water. 32.5% urea and 67.5% deionized water. Over time heat can cause the water to evaporate and the fluid can settle out somewhat, changing its ratio. Dirt can chemically change DEF as well too so any dirt in the containers and/or tank can chemically ruin DEF.
    pushbroom Thanks this.
  5. stillwurkin
    stillwurkin Road Train Member
    1,756
    2,856
    Dec 2, 2017
    I just read the first few comments. Can't help but just wanted to say. It's a shame a person buys a good used truck and then has to deal with DEF issues. All those sensors enough to drive you insane. Hope you get it figured out.
  6. DYLAN_131
    DYLAN_131 Light Load Member
    136
    131
    Nov 21, 2018
    When DEF sits to long it can "salt out". No such thing as a "bad batch" of DEF. However, you could be pulling DEF out of a bad tank (commonly at "mom and pop" truck stops) due to poor tank cleaning and management.
  7. MartinFromBC
    2,769
    12,484
    Oct 19, 2018
    Actually there is such a thing as a bad batch. Ask the many locals who bought it from Canadian Tire a few years ago and had massive problems, then it was recalled.
    Its terrible stuff, and outrageously expensive for water and basically horse pee.
    Nothereoften Thanks this.
  8. DYLAN_131
    136
    131
    Nov 21, 2018
    No, there isn't such a thing, unfortunately. Every batch is tested for correct concentrations. Reasoning being is because inside DPF systems, they are calibrated for the urea concentration to provide proper NOx reduction. It is expensive, and ridiculous to have been mandated.
    Canadian Tire most likely accidentally or inadvertently contaminated their batch. This can be done fairly easy.
  9. MartinFromBC
    2,769
    12,484
    Oct 19, 2018
    Will have to agree to disagree.
    Some places make better quality def than other places do daily. And sometimes a bad batch gets made, just like anything else. I have hauled fuel for 3 decades, and even the same refinery doesn't make the exact same fuel every day forever and ever. Sometimes the fuel is of a lower quality, they try to get the next batch better again. For what def is its price is just insane that is a fact. Should be about 5 cents a liter.
    pushbroom and spsauerland Thank this.
  10. DYLAN_131
    136
    131
    Nov 21, 2018
    Fuel and DEF are different and have different guidelines. The API and ISO say otherwise to the "bad batch" or "poor quality" DEF. Concentrations are standardized, regulated and tested. Hauling it's one thing... being inquisitive of those working with it is different... you're not the only one that's hauled.
  11. MartinFromBC
    2,769
    12,484
    Oct 19, 2018
    Yes and manufacturers miss the target on quality all the time.
    So we will never agree.
    Hopefully oneday soon the engine makers come up with an emissions system that doesn't use def at all, making every truck driver and equipment operator happy.
    Nothereoften and pushbroom Thank this.
